Tcs C1235
Old Aug 7, 2007 | 11:00 PM
Irish Whiskey's Avatar
Irish Whiskey
Default Tcs C1235
Got this code along with a couple of others that reset. This one, C1235, did not reset. Know it is right rear sensor problem. Any ideas?
Old Sep 22, 2007 | 11:01 PM
NSPharmD's Avatar
NSPharmD
I have the same thing. All of the other codes cleared, except that one. anyone out there know what to do???
thanks,
Nick
Old Sep 23, 2007 | 07:24 AM
trussme's Avatar
trussme
YES....C1235 RR Wheel Speed Circuit Open or Shorted
Wheel Speed Sensors
. one of the wheel speed sensors is either sending a bad signal or no signal. Start by checking the connections. The wheel speed sensors are integrated into the wheel bearing/hub assembly . The wire coming out of the back is the connection for the wheel speed sensors. Verify that the connector are not broken, damaged, or corroded in any way. Pay particular attention to the female end.
The wire coming out of the wheel speed sensor connects to and 18" jumper harness, then to the main harness. It is very common for people to have a weak female pin in one of those connections. If all of that checks out good, Swap the jumper harness from side to side. For example if the left front is bad, swap it over to the right front. and install the good one from the right front to the left side. Then clear the trouble code. If the trouble code is now on the right side, you know the wire harness is the problem. If the code is still on the left side after swapping the jumper harnesses, you know the problem is inside the wheel speed sensors.
If all the wires check out good, it's time to take a trip to Auto Zone for a new set of bearings. You can buy replacement AC Delco bearing from your dealer if you want to, or get the exact same bearing in a different box for half the price (~$150) from Auto Zone, you decide. The bearings should be replaced in axel sets, so if your left front is bad, you have to replace the right front too. While your at it, this is a good time to upgrade the lug studs and add spindle ducts.
To Tcs C1235
