electrical problem
Old Aug 8, 2007 | 06:17 PM
wildcatgs's Avatar
wildcatgs
Default electrical problem
car gave me the codes for traction and lost power. went through all the gounds cleaned them all and all were pretty good. the battery had some corosion on the poss cable all ceaned now. the problem is when the car is started the amps show 13.1 if i put on the a/c or the lights it drops into the 12.8 range. if i put the rear defrost on it drops to 11.5 and stays there once i shut it off it will go back to 12.8 never over 13. could this be the battery or altinator? any ideas? thanks
Old Aug 8, 2007 | 06:58 PM
wildcatgs's Avatar
wildcatgs
also codes 1571h and 1255h keep coming up even after i clear them
Old Aug 8, 2007 | 10:28 PM
wildcatgs's Avatar
wildcatgs
ttt
Old Aug 9, 2007 | 10:00 PM
wildcatgs's Avatar
wildcatgs
anyone?
Old Aug 9, 2007 | 10:16 PM
RossJackM's Avatar
RossJackM
How did you get the plug separated to clean the ground plugs? Does the plug have a plastic tab that has to clear ? Help!
Old Aug 10, 2007 | 08:50 PM
wildcatgs's Avatar
wildcatgs
yes use a small srewdriver on both sides comes right off
Old Aug 10, 2007 | 09:00 PM
FRCTony's Avatar
FRCTony
Doesn't appear to be charging, so alternator or battery, assuming the wiring is good. You need to test them.
If the battery is old, I would replace it and recheck.
Old Aug 11, 2007 | 12:16 AM
RossJackM's Avatar
RossJackM
Default Thanks!
Thanks! will try, seems to be corroded shut! Good luck on your problem. Jack
Old Aug 11, 2007 | 11:19 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You will get voltage drops due to load. If you raise the rpm level by applying some gas it (voltage) should go up, if not you'll need to check you connections, battery, alternator.
Old Aug 11, 2007 | 11:32 AM
FRCTony's Avatar
FRCTony
You should not see 11.5v with the engine running. Thing is, this should trigger a low voltage warning that was not mentioned...
My money is still on a bad battery.
Old Aug 11, 2007 | 04:46 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I just was stating that you'll get some voltage drops due to loads from turning on various electrical appliances.
I don't know what set-up he has like a 10% under drive, etc and he didn't give much info to go on.
Old Aug 11, 2007 | 07:56 PM
wildcatgs's Avatar
wildcatgs
car is stock i do get the load but it should come back after giving it some gas and it doesnt am going to replace the battery tomorrow and see what happens,
Old Aug 12, 2007 | 09:15 PM
wildcatgs's Avatar
wildcatgs
well replaced battery today but it still seems like its charging low. stays at 13 and sometime drops around 12.6. is this nomal?
Old Aug 12, 2007 | 09:23 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
That's what mine does. My other C5's averaged 12.5 - 14.0 depending on load.
Old Aug 12, 2007 | 09:35 PM
wildcatgs's Avatar
wildcatgs
its been driving me nuts because i think it used to be higher. i have spent so much time on this cleang grounds and all. was cocerned because the sevice engine reduce power thing happened and thought it was because of the charging system being low now it seems the only problem is i keep getting a history code after clearing it several times the code is p1571h
Old Aug 12, 2007 | 11:11 PM
FRCTony's Avatar
FRCTony
That is normal for a fully charged battery. Leave your lights on with the car off for 15-20 minutes and then see what you get.
To electrical problem
