Help...No A/C or Heat??
Old Aug 8, 2007 | 08:16 PM
GOWINGS's Avatar
GOWINGS
Default Help...No A/C or Heat??
Well just like the title says I went to take the car today in this crazy georgia heat (112 with the heat index!) and the AC was not working so I tried the heat and nothing, the display is lit up and indicates the settings but nothing blowing?? What should I check first before I have to take this thing in. Thanks for any information!!
Old Aug 9, 2007 | 07:43 PM
GOWINGS's Avatar
GOWINGS
Anyone....Any Ideas?
Old Aug 9, 2007 | 08:22 PM
ronwc's Avatar
ronwc
Check and clear any codes from the DIC - if that doesn't help, check your fuses - after that you may want to disconnect your battery to reset everything -
Old Aug 12, 2007 | 04:09 PM
GroundFlyer's Avatar
GroundFlyer
St. Jude Donor '19
Just had the same thing happen to my 04 vert. The blower motor was plugged with insulation from an industrious mouse. Remove the blower mtr to clear it and run a vacuum up the duct work to suck out anything else that might be in there.
To Help...No A/C or Heat??
