When to Replace Brake Master Cylinder?
Old Aug 9, 2007 | 06:07 PM
CSIXVET's Avatar
CSIXVET
Default When to Replace Brake Master Cylinder?
What is the collective experience, how long does the brake master cylinder last?
Time?
Miles?
Replace with 100K major mantenance?
What do you think/what did you do?
My car will be eight years old next month, it's on my mind!
Old Aug 9, 2007 | 06:59 PM
TLewis4095's Avatar
TLewis4095
Time?
Miles?
We have seen almost no failures with the C5 master cylenders. A fluid flush & change will be highly recomended, but that is about it. And there really is no 100,000 mile major maintenance....change all fluids, belts, hoses, but that is about it. Expect 250-300,000 miles plus before you need an engine reuilt, and if you don't abuse it the trans should last near as long. Do a search on C5 high mile cars and you will be amazed at how many have 150-200-250k miles on them & still not burning oil, etc.
Old Aug 9, 2007 | 10:04 PM
Dave00C5's Avatar
Dave00C5
Master Cylinders only need to be replaced when they fail to operate or leak.
Old Aug 9, 2007 | 10:12 PM
genchevy19's Avatar
genchevy19
My 1999 had a master cylinder problem that was causing the front brakes to hold pressure. It only has 27,000 miles on it. The fluid looked contaminated but flushing it out did not help. I replaced the master cylinder for under 200 hundred dollars.
I would not mess with it unless there is something wrong with it. Flushing the fluid probably would not hert.
Old Aug 10, 2007 | 10:15 AM
Buckskinner's Avatar
Buckskinner
Default long, long, long, time
ah ain't never had ta do nutin ta mine, It be 10 year ol an got 250,000 mile on it. ain't never had no trouble wif it.
Old Aug 10, 2007 | 10:17 AM
Buckskinner
trans started slippin in 4th bad, an a little in third @ 203,000
thet be on tha riginal trans awl frum tha factree
To When to Replace Brake Master Cylinder?
