Smog Pump Removal
Old Aug 9, 2007 | 09:04 PM
D Lamberet's Avatar
D Lamberet
Default Smog Pump Removal
I am installing an A&A supercharger. I am planning on deleting the smog pump. Has any one done this and what to look for in doing so.
I am running HP tuner so as to allow disabling the feature. Can anyone shed light on what to look for? Also no smog inspection where I live as well
danny
Old Aug 9, 2007 | 10:31 PM
speedsk899's Avatar
speedsk899
If you are talking about the airpump that pumps air into the exhaust on warm up I can help. I took mine off because the headers I out on do not have the hook ups. I am tuned with HP tuners and yes you can delete it. The worst part was removing the air tube that runs behind the intake. I had to remove the intake to disconnect the mount behind the intake. You will also have to plug the hole in the air filter assembly, I used the plastic cap from a white board cleaner bottle. If you are not changing the headers you will have to block off the airtube hook ups on the headers.
Old Aug 9, 2007 | 10:51 PM
123sugey's Avatar
123sugey
Dig
What about the tubes that run under the fuel rail covers ?
Old Nov 28, 2007 | 08:27 PM
chris308's Avatar
chris308
instead of starting a new thread i resurrected this one!!
i'm going to be removing my smog pump when i do my intake mani swap, whats a good way do block off the fittings on the headers? Anyone have any tips on a DIY block-off plate?
Old Nov 28, 2007 | 08:30 PM
D Lamberet's Avatar
D Lamberet
Default Air tube block offs.
I went the easy way. Thunderracing sells the plates to block off the air fittings. They weren't cheap but are stainless and easy to install.
danny
Old Nov 28, 2007 | 09:34 PM
chris308's Avatar
chris308
thanks Danny
Old Nov 29, 2007 | 08:59 AM
123sugey's Avatar
123sugey
Dig
You can cut off the tubes from the plates and weld the holes shut.
To Smog Pump Removal
