c5 vert top adjust.
Old Aug 10, 2007 | 12:46 PM
danlbika's Avatar
danlbika
Default c5 vert top adjust.
My 04 manual convertible top has been leaving rub marks on the tonneau cover from day one whenever the top is raised and lowered. It looks like the metal ribbing on each end is causing the problem. Is there any adjustment that can be done to correct this ???
Old Aug 10, 2007 | 12:56 PM
middlebrookgt's Avatar
middlebrookgt
if you will do a search in this forum and the C5 general one, there are threads that address adjusting the top. I adjusted mine as directed in about 10 minutes, and fixed a window gap and rubbing top problem.
Old Aug 11, 2007 | 10:09 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
http://www.c5forum.com/cgi-bin/ultim...ic/1/2213.html
To c5 vert top adjust.
