Headlight Problem, NEED HELP
Old Aug 11, 2007 | 12:26 PM
elctron02's Avatar
elctron02
Default Headlight Problem, NEED HELP
Heres the story. One day my headlights would not go up. Finally after many tries, they did. Played around with them but the driver side light would go up and continue to click b/c the motor was still rotating. then when down samething happens. they go down and continue to click for a few seconds...motor is still rotating.
so I thought it was the Control Module under the pass side light. I replaced it from GMparts direct. Installed it today but the samething happens. goes up and continue to rotate the motor and goes down and continues to rotating the motor for a few sec. the clicking are the gears inside the motor. ONLY on Driver side.. Pass side is fine!
so, do i need a new motor, or is it something else? the motor rotates longer than it should.
Please help!!!
Old Aug 11, 2007 | 12:30 PM
Jboger2K's Avatar
Jboger2K
Sounds like gear replacement time. There is a great post on the general general discussion on how to diys. I just did my driver side.
Old Aug 11, 2007 | 12:39 PM
elctron02's Avatar
elctron02
I checked the gears. they are fine... does the motor need a load on it to work right
Old Aug 11, 2007 | 03:18 PM
elctron02's Avatar
elctron02
disregard last statement. I took apart the motor again. gear is worn in 2 spots. Just order brass gear. hopefully that is the case. if not, i will be on again. thanks all
Old Aug 11, 2007 | 09:03 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
How did you take the motors apart twice? I assume your car is an '02 because of your username. Only the '97-early 2000's had gear housings made from aluminum that came apart with bolts. The late 2000's-'04s have plastic gear housings that epoxy together.
Old Aug 11, 2007 | 11:45 PM
elctron02's Avatar
elctron02
I first took apart the motor (main body) and looked in while rotating the gear. looked fine..however I then disconnected the plastic today.. gear is now worn.....
To Headlight Problem, NEED HELP
