installing a stereo
Old Aug 12, 2007 | 03:01 PM
watsonsvett's Avatar
watsonsvett
Default installing a stereo
ok well my keyless entry doenst work and now my computer is having problems. i put a new stereo in there and after that all of this started messing up. it is a 1998 ls1 and all i need to know is that when i replaced the stereo is the computer tied into it or not
Old Aug 12, 2007 | 05:09 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What message are you getting ? It recognizes the radio, all you might get is a loss of communications, everything else should work fine.
Old Aug 12, 2007 | 11:11 PM
lionelhutz's Avatar
lionelhutz
The computer is on the data buss but it doesn't mess up anything when you disconnect it. I guess if you hooked something to the data buss you could cause problems.
The data buss is pin 16 orange wire on bottom plug. Put lock tab on top and pinn 11 is bottom right when looking at wire side of harness.
Peter
Old Aug 12, 2007 | 11:16 PM
watsonsvett
ok so it doesnt matter that i have 2 wiring harnesses left over and only one pluged in
Old Aug 12, 2007 | 11:42 PM
noahdr's Avatar
noahdr
the two smaller plugs are for the bose module. go to the audio/electronics forum, plenty of info in there.
Old Aug 13, 2007 | 12:36 AM
Kale's Avatar
Kale
Check that box to the side of the speaker on both doors. They are color coded. Sounds like you got one in the wrong spot in one of the doors.
Its very possible to plug them in wrong!
Old Aug 13, 2007 | 06:01 PM
lionelhutz's Avatar
lionelhutz
you could start by describing what you removed and what you installed and how you did it, as in provide the details. noone has any idea what you actually did when you say "stereo install".
"stereo install" is so open it could mean a bunch of things and is useless just telling us that.
im my last post i meant the radio is on the data buss and wire is in connector as i described. mess with it and you can stop data buss communications which messes up all systems in car.
Do the DIC self tests, hopefully someone can post link i don't know where it is right now.
Peter
To installing a stereo
