ARP Head bolts question
Old Aug 12, 2007 | 03:03 PM
123sugey's Avatar
123sugey
Dig
Default ARP Head bolts question
When installing ARP head bolts, do you just lightly lube (w/ motor oil) them befor install ?
Anything else i need to know ?
Old Aug 12, 2007 | 03:05 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
If you dont mind me asking this question in the same thread....Are you supposed to change the head bolts when you change the heads ?
Old Aug 12, 2007 | 03:39 PM
123sugey's Avatar
123sugey
Dig
Yes, you have to change stock head bolts when changing heads ( 1- time use).
The ARP's are reusable.
Old Aug 12, 2007 | 03:40 PM
Corvette-Chris
St. Jude Donor '08
Thats good to know cuz I just bought some AFR's Thanks
Old Aug 12, 2007 | 06:24 PM
vettenuts's Avatar
vettenuts
I would use the ARP Assembly Lube myself, I usually put it on with a plumbing brush and coat the threads.
Old Aug 12, 2007 | 06:50 PM
123sugey's Avatar
123sugey
Dig
vettenuts..... your kind of like my personal help line !! You've responded to almost every thread i needed help in !! THANKS
Old Aug 12, 2007 | 08:03 PM
RennfahrerX's Avatar
RennfahrerX
ARP includes a torque spec sheet with their bolts and studs. The required torque values are different depending on whether you use oil or moly lube. Either way, be sure to coat the threads and the underside of the bolt head or nut (if using studs).
Doug
Praetorian Racing
Phoenix, AZ
Old Aug 12, 2007 | 08:49 PM
Corvette-Chris
St. Jude Donor '08
So can someone give me a part number or point me in the right direction on which ARP head bolts to get ? Thanks
Old Aug 12, 2007 | 11:25 PM
spiral04's Avatar
spiral04
I am doing my head and cam package right now but I sprang for the head studs instead of the bolts. They are a little more money but you never have to clean the bolt holes out(would with bolts if ever removed) and I do believe the studs hold better. Someone else with more knowledge on this can chime in!
Old Aug 13, 2007 | 12:18 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
ARP has bolts and studs, I prefer the studs. They came with the lube for the studs
Old Aug 13, 2007 | 12:22 AM
123sugey's Avatar
123sugey
Dig
Thanks for the help.
Old Aug 13, 2007 | 12:33 AM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
123 I went with the ARP Head bolts as well on my H/C package, pretty much because they are reusable (vice the torque to yield factory bolts). Not sure what Howard did though for prepping them prior to installation
Old Aug 13, 2007 | 05:48 AM
vettenuts's Avatar
vettenuts
Clean the threads in the block real good, make absolutely sure the holes are dry right to the bottom. Before installing the heads, I would lube each bolt and screw it in and out of each hole by hand to make sure all the bolts run in nice and smooth. Clean any lube/oil that may have gotten onto the block where the gasket goes, then install the gaskets and heads. I think you will find that the stock bolts leave behind some red gunk that will make the bolts go in a little harder the first time. For stock bolts, this doesn't matter as the preload on the bolt is actually measured by rotation. For the ARP's, which use a torque value, friction will play an important role in obtaining the correct bolt stretch.
Old Aug 13, 2007 | 11:33 PM
123sugey's Avatar
123sugey
Dig
Heads are on !!
Thanks everyone for the help
Old Aug 14, 2007 | 08:13 PM
vettenuts's Avatar
vettenuts
To ARP Head bolts question
