Today my A4 bit the dust
Old Aug 12, 2007 | 06:24 PM
richieice's Avatar
richieice
Default Today my A4 bit the dust
Driving at about 65 and I lost all gears above 2nd gear. Spoke to two people (both vette owners). One says to rebuild and the other says to get a rebuilt one from a rebuilder with stronger parts. Basically with a car with 70K on the clock, should I bother rebuilding?
Old Aug 12, 2007 | 06:44 PM
Dave68's Avatar
Dave68
Although I don't have an A4, I've heard many times that it is safer (more likely that you will end up with a reliable tranny) to buy a factory rebuilt tranny with all the latest upgrades. I've heard and read of so horror stories regarding indepemdently-owned shops' rebuilt trannies, that I would stay away from that scenario unless you personally know someone who's had good luck over many years of having his tranny rebuilt by the place.
I've also found this to be true of engines - a factory crate engine is very often more likely to give you 100,000+ miles of life, compared to home-rebuilds or rebuilds from mom & pop engine shops. At least, this has been my experience when I had my 68.
Old Aug 12, 2007 | 07:32 PM
torchvette10's Avatar
torchvette10
Please do yourself a favor and get a new built tranny!
Contact Rodney or Todd at RPM transmissions
www.rpmtransmissions.com
These guys are the best of the best, period!!! Thei trannies are very strong and they take abuse from cars with over 700 RWHP. I have their Level 5 tranny and I couldn't be happier. I make between 450-500 RWHP and their tranny has been hloding up great and I am driving my car really really hard!
It takes everything you throw at it! I just wanted to share my experience as I am an extremely happy RPM customer!
Old Aug 12, 2007 | 07:37 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
If or when mine goes.......
I will be getting one from RPM transmissions
http://www.rpmtransmissions.com/
Old Aug 12, 2007 | 08:19 PM
TLewis4095's Avatar
TLewis4095
Where are you located? The built trannies start out as OEM stock units & are modified from there.
Old Aug 12, 2007 | 08:48 PM
widewheel's Avatar
widewheel
Had a similar experience. My top two gears dropped dead at 77,000 miles. I looked around and had several options. The problem with a rebuild was that no shop would warrenty their work and it was going to cost about $2,000. I considered an RPM and then went to a local dealer that I've had real good luck with (they have a couple of really good Vette techs) and they quoted pretty much the same price as the installed RPM. The only difference is the GM has a 3year/100,000 mile warrenty. Granted I probably won't drive 100,000 miles in the next three years, but 36 months is a long time. Another thing, I was going to have to find a shop that I thought was competent enough to do the work of removing and then installing the RPM transmission. My advice is to call around and examine all of your options carefully. When you get to the point where you have narrowed your options go to the shop/dealership and look at the quality of the operation and then get a written quote. Good luck.
Old Aug 12, 2007 | 11:12 PM
4DRUSH's Avatar
4DRUSH
I second that!!!!!!!!
Old Aug 13, 2007 | 03:28 PM
richieice's Avatar
richieice
I really appreciate all of the feedback. I had the car towed to a real good vette mechanic in LI. Not going to go with the rebuild and spoke with the folks over at RPM this AM. Basically the only thing I wanted to ask you guys was that during my conversation with RPM, they said that the car would have to be re-tuned back to the original stock line pressure. The car was tuned by the same people that have it now so it should not be an issue but is this really the case, did RPM make a trans that does not need to be tuned?
Old Aug 13, 2007 | 04:02 PM
torchvette10
Hi there,
wait until someone more competent adds some info but in the mean time, I believe that the RPM tranny is built as to provide sharp and quick shifts, and I clearly noticed that when I installed mine. It also enables the tranny to take the extra power. However adding pressure over that is kinda overkill and reduce the tranny longevity
Old Aug 14, 2007 | 10:15 AM
Buckskinner's Avatar
Buckskinner
Default a4
mine kinda dun thet too. but didn't go out alluva sudden. Started slippin in 4th a little then got worse over a couple thousand miles, then started slipping in third. had a feller over in Mansfield Texas rebuild it. former GM tech. took it out rebuilt er ( OEM parts) put er back in, while he had er out he dun the diff. & axle seals replaced tha diff grease+LSD additive. charged me $1,400.00 fer tha whole thang. no problems wif it so far got 30 sumodd thousand on it.
Old Aug 14, 2007 | 01:08 PM
MattB's Avatar
MattB
The RPM transmission has a shift kit in it, I think having high line presures from a tune will put too much pressure on the trans and shorten the life. But, talk to RPM they will tell you exactly why.
Old Aug 14, 2007 | 02:34 PM
tiojames's Avatar
tiojames
Whichever tranny you decide on, be sure that all the lines and the cooler(in radiator or after market) are flushed really well.
Old Aug 14, 2007 | 07:06 PM
Rhode Warrior's Avatar
Rhode Warrior
I wont. I got a stage IV A4 from Rodney. Put about 4,000 miles of mostly easy driving on it and it now bangs hard when shifting from 1st to 2nd. I sent an e-mail on Saturday to RPM describing the problem in great detail and still have yet for them to respond. From now on, I'll just deal locally.
Old Aug 14, 2007 | 07:46 PM
torchvette10
Holly cr@p!! I really hope you will be fine! Please keep us posted when you get a reply from them. You might want to give them a call.
I am really sorry to hear about your misfortune
Old Aug 14, 2007 | 07:54 PM
fsuforever's Avatar
fsuforever
I have done both ,had a tranny mechanic locally build me one , 1 month later he was trying to rebuild it again ,After i brought the car home that evening, i pull it out of the garage to find tranny fluid Leaking , it broke a month after the install so there are 2 ,then someone recomennded finish line transmissions , Chuck Johnson ,bought one from him & havent had any issues O ya i also went from a 3200 yank to a 36 00 yank get @ least a 3600 & from a reputable builder & you should be Fine i also go to the track twice a month
Old Aug 15, 2007 | 12:56 AM
4DRUSH's Avatar
4DRUSH
This is very important. Any debris in the lines will ruin your new trans. Also have your TC flushed out.
Old Aug 15, 2007 | 08:29 AM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Seeing how my father passed away Friday evening and I have been with my family since is probably why I have not answered my E-mails. Some E-mails that do not require my personal attention have been answered but I am sorry that yours has not. To answer your question have you put a Tech II scanner or some sort on your car and looked for trouble codes? I bet you will find one (I realize the check engine light might not be on). Do you have someone local who has a scan tool. The main thing to look for is TCC slip while TCC is applied. My bet is that you will find the problem right there. If I remember correctly you are running a Fuddle converter.Before juming to conclusions I will bet it is NOT in the transmission. Please call us with questions its toll free and won't cost anymore than a local call. 1-800-406-1109 RODNEY
Old Aug 15, 2007 | 09:30 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Sorry about your Dad Rodney, lost mine a few years ago and I sure do miss talking/hanging out with him.......... take a deep breath
Old Aug 15, 2007 | 11:28 AM
Rhode Warrior
As I was about to retract this statement because in fairness to RPM I haven't even called them yet, I received a PM from Rodney. And even though I jumped the gun and posted the above response before I spoke to him, he was still very helpful and is helping me with my issues. Hats off to Rodney for being a class act.
To Today my A4 bit the dust
