My steering column in my 03 Z06 is stuck in the most upright position, it's like I'm driving a bus! Can someone please give me some suggestions on how to fix this issue? Thanks.
P.S. I installed a corvettes of Houston CLB today but to the best of my knowledge I never adjusted the wheel prior to or during installation.
So its the tilt and not the telescoping portion. Is there tension on the tilt lever such as the spring return on the lever? Oh, my '99 Coupe has both tilt and telescoping so it wasn't Z's only.
Either way, you will need to remove the upper and lower steering column covers and see if you can find what's up with it. I know there is a pivot pin in there that may have backed out.
Reason: Add
