Sway bar question...
Old Aug 12, 2007 | 08:57 PM
SebringSixSpeed's Avatar
SebringSixSpeed
Default Sway bar question...
I am thinking about getting a set of hotchkis bars to get rid of a little bit of body roll and was wondering if they would be dangerous on the street, not letting the suspension work independently enough for rough back roads. Please if you know something about how this works post a response. thanks! (btw I am running Z wheels with PS2's and stock F45 suspension)
Old Aug 13, 2007 | 08:59 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
There are a number of people on here running the hotckis anti-roll bars or something similar (T-1 or pfadtty bars) and report improved handling. However, if you get get on a really bad piece of road my guess is you will get bounced around a lot. He!!, even in a stock vette you will get bounced around pretty good. Stiff suspensions and lousy roads to not mix well!!
Here is a link that might give you some more info.
http://auto.howstuffworks.com/question432.htm
Old Aug 13, 2007 | 09:43 AM
FRCTony's Avatar
FRCTony
Z06 bars are a much better value IMHO, and would have slightly less impact on ride.
Old Aug 13, 2007 | 09:45 AM
jovette's Avatar
jovette
Why not go with the Z06 front and rear sway bars and end links? That's what I did. Under $300, total, and she really corners well, with no noticeable decrease in ride comfort.
Old Aug 13, 2007 | 10:59 AM
TorchRed00FRC's Avatar
TorchRed00FRC
Here are sway bar dimensions.
23mm, front; 19.1mm, rear --- Base
Z51 (97-99): 25.4mm-front / 21.7mm-rear
Z51 (00-04): 28.6mm-front / 23.6mm-rear
Z06: 30.0mm-front / 23.6mm-rear
Hotchkis: 31.75mm-front / 25.4mm-rear
T1 (GM Racing): 38.4mm-front / 27.5mm-rear
I do not know what size sway bars come with the F45 suspension. Guess would be the base sway bar set. I also think the F45 suspension has the base spring rate too. Perhaps get answers to that question.
You may want to do a combination of sway bar and spring swap to get the ride you desire.
Old Aug 13, 2007 | 11:15 AM
The Spark's Avatar
The Spark
The F45 does have base springs and sway bars.
Old Aug 13, 2007 | 11:37 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
I have had the Hotchkis sway bars on my 99 for 90,000 miles with no handling problems. I did manage to break two of the Hotchkis end links.
Old Aug 13, 2007 | 11:41 AM
LTVetteVert00's Avatar
LTVetteVert00
Will this solve the end link popping sound that some folks hear when they turn sharply to the left? Reminds me of a bad ball joint from long ago.. .
LT
Old Aug 13, 2007 | 01:21 PM
waupachino's Avatar
waupachino
I have the Hotchkis sway bar set up along with Bilstein Sports shocks. I had the base suspension before. The car now feels like it is glued to the road in turns and feels much more stable at higher speeds then before.
Old Aug 13, 2007 | 01:48 PM
SebringSixSpeed
Ok, thanks for all the responses. It cleared things up a bit for me.
Old Aug 13, 2007 | 01:49 PM
craig04c5's Avatar
craig04c5
I have the Z06 sway bars also.
Old Aug 13, 2007 | 03:11 PM
BitViper's Avatar
BitViper
Mann..thoes T1's are massive!
Old Aug 13, 2007 | 06:15 PM
MattB's Avatar
MattB
I have Hotchkis and drive a mile of dirt road a day, no issues. I like a stiff Vette though LOL... Anyway, I would definately look at Pfadtty as I think they may be better. The old adjustable end links from Hotchkis make a lot of noise, made me think I had broken something. I switch to the GM metal end links and all is good now. Not sure if the new adjustable end links solved the issue for good or not. Go take a look at Pfadtty's bars though, they look impressive
To Sway bar question...
