A4 fluid level check
Old Aug 13, 2007 | 12:52 PM
torchvette10's Avatar
torchvette10
Default A4 fluid level check
Hi guys,
what is the proper way to check the A4 fluid level? What temp does it need to reach, does it need to be checked on Drive?
Please let me know, thanks in advance!!!
Old Aug 13, 2007 | 03:02 PM
C5SMAJ's Avatar
C5SMAJ
Im curious also....
Old Aug 13, 2007 | 03:11 PM
TLewis4095's Avatar
TLewis4095
With it up in the air, car level running in park, remove fill plug and just enough should spill out indicating full. If no fluid drips out add a small amount at a time (use a fluid pump from auto parts store) until it drips out. Then your full. Replace plug, shut off engine, lower car.
Old Aug 13, 2007 | 03:14 PM
torchvette10
Awesome, thanks a lot!!!
Old Aug 13, 2007 | 05:01 PM
MattB's Avatar
MattB
You have to have it warm, otherwise its not sending any fluid to the cooler. Can't say for sure what temp it opens, maybe 140?
Old Aug 13, 2007 | 05:55 PM
94legaleagle's Avatar
94legaleagle
I THINK the service manual says 187 degrees is the temp to check it at, but I don't remember for CERTIAN.
Old Aug 13, 2007 | 07:07 PM
MattB's Avatar
MattB
We were both wrong, my 2000 GM service manual says 86 to 122f.
To A4 fluid level check
