dtc 1233
Old Aug 12, 2007 | 10:49 PM
fsuforever's Avatar
fsuforever
Default dtc 1233
Well i am Having some Traction control issues as well , didnt wanna hijack the last guys thread ,i just Bought wheels & Tires for my 00 c5 & drive the car only on weekends since i can only seem to get 1 day off in 2 weeks , so i get in the car & drive out of the Drive way to have the abs,tcs, abs service , tcs c1233 come up on the Dic ,when i hit 10 mph, Like i said i replaced wheels & took the front 2 tires off the old wheels & put them on the new wheels ,its been 4 or 5 weeks since the change but did not recieve any codes after 100 miles of driving with new wheels , then right out of the Blue i get a 1233 , does anyone have any experience in changing out the bearing/hub /wheel sensor , i hear its all one pieice ,is this correct ? if it is , is it pressed on? i read somewhere it was 150.00 @ auto zone ?
Old Aug 13, 2007 | 06:42 AM
fsuforever's Avatar
fsuforever
ttt
Old Aug 13, 2007 | 10:30 AM
trussme's Avatar
trussme
Here's what I have that MAY help to check out:
Could be one of the wheel speed sensors is either sending a bad signal or no signal. Start by checking the connections. The wheel speed sensors are integrated into the wheel bearing/hub assembly. The wire coming out of the back is the connection for the wheel speed sensors. Verify that the connector are not broken, damaged, or corroded in any way. Pay particular attention to the female end.
The wire coming out of the wheel speed sensor connects to and 18" jumper harness, then to the main harness. It is very common for people to have a weak female pin in one of those connections. If all of that checks out good, Swap the jumper harness from side to side. For example if the left front is bad, swap it over to the right front. and install the good one from the right front to the left side. Then clear the trouble code. If the trouble code is now on the right side, you know the wire harness is the problem. If the code is still on the left side after swapping the jumper harnesses, you know the problem is inside the wheel speed sensors.
If all the wires check out good, it's time to take a trip to Auto Zone for a new set of bearings. You can buy replacement AC Delco bearing from your dealer if you want to, or get the exact same bearing in a different box for half the price (~$150) from Auto Zone, you decide. The bearings should be replaced in axel sets, so if your left front is bad, you have to replace the right front too. While your at it, this is a good time to upgrade the lug studs and add spindle ducts.
To dtc 1233
