Altec Splash Guard fix
Old Aug 13, 2007 | 11:51 PM
C908's Avatar
C908
Default Altec Splash Guard fix
I recently installed the Altec splash guards and was very concerned about clearance problems with the front ones. On my first day with them being very careful I still had a slight scrape pulling into my driveway. I read a post where someone hit one hard enough that it cracked his fender. I decided not to chance it and removed the front ones to modify a little bit. I removed two inches from the bottom which will leave just enough for the bracket to still be there to attach from underneath. To take care of the edge where I cut them I attached black door edge molding which gives them a finished look. I had also taken the advice from someone else and used the door edge molding on the edge that makes contact with the paint. Overall I am now very pleased with them.
