Will the 2001-2004 LG PRO headers fit my 1999 FRC? I assume the only difference is the air tubes versus the 1997-2000 set. I am running block off plates on my TPIS headers now. My air pump is turned off. Also how much RWHP do the high flow cats take away?
They should fit w/o a problem you have the block offs for the air pump..hi-flo cats will add RWHP.
Yes high flow cats add hp versus stock cats but how much rwhp will I get if I leave off the random tech high flow cats on the LG PRO system?
This was your question "Also how much RWHP do the high flow cats take away?"
Hi-Flo cats don't take away any RWHP..you gain RWHP...not sure how much from brand to brand of hi-flo cats...some say 5RWHP with hi-flo cats and some say 10RWHP with them 0ver OEM cats.
Did you mean, How much HP do you lose in comparison to not running cats?
I was told that Random Tech vs. No cats is only a differnce of like 3-5 hp on the Dyno. - Not sure how accurate this is, but it is what I was told.
Yes thats what I was trying to get across. Thanks guys for the info.
I was told awhile back by some one who use to work for random tech,you may loose a few hp running a hi flo cat compared to no cats,but make up for it in torque
