What the Hell.. No Comm.
BO - RFA No Comm.
What the hell is wrong with the car... everything seems to be working fine but the damn thing is saying that i do not have any comm.
also another thing.. RTD is pointing out that my steering position signal is not working.. could that be a reason for the " Service Ride Control"
RFA: NO COMMUNICATION is Radio Frequency Setting's
Which will includw Tire pressure monitors and Key FOB's etc.
Diagnos which one is giving the trouble and or the BCM might be the source.
Check your manual and see if it tells you anything about this in the trouble code sections.
I believe the only way to access the RFA is with a TECH 2 to reset the setting - somonw correct me if I'm wrong! (It's early 3:49AM)
Thanks,Matt
Thanks,Matt
Thx Matt..actually i removed the TPS from my rims due to the swap of rims.. also my Key Fob is lost and i still did not buy another one
that might be it.
