Leverage is what you want, so a pipe onto a ratchet handle works wonders. That's what i would have done, if I didn't have 3 impact guns.
i also saw where someone set the wrench on the bolt and ground, and then lowered the car down to use it's own weight.
Dang you fancy lads with your impact wrenches!
I remember reading about that method in advance, it just made me a little nervous fooling with the jack (even though there were also stands in the equation).
i didnt put any of that when i reassembled them... does that mean that i have to go back and re do everything? is it really that important?
by the way my palms still hurt
Oh jeez, I know it's painful to redo, but for the brackets that actually hold the calipers on, I don't know if I'd (personally) feel comfortable without some LT. Though I know some folks who track often say they don't worry about it since they're constantly doing maintenance on the brakes.
If it's any consolation, I had to swap my calipers on the front and rear to the opposite sides - while the mounting isn't side specific, the location of the bleeder valve IS, otherwise you'll never clear the air out.
Mickey,
If you got an honest 125 lb-ft on them, you're good to go. If you don't know, or if you know you didn't, then (deep breath) you'd better go back.
The racers use 125 lb-ft, and don't worry about locktite, because as soon as the bracket gets hot (out on the track, not on the street) the locktite softens, and then what's the point?
