Headlamp Motor Headache
I rebuilt my headlight motors a couple of days ago with the bronze gears I ordered from Corvette Central. I followed the instructions exactly and replaced them in the fully raised position with the headlamp switch on. When I turned the switch off the headlamps stayed up and when I turned the headlamp switch ON again, they went down! They are exactly opposite of how they should be. When the switch is OFF the headlamps are up and when the switch is ON the headlamps are on but the assembly is down. I have tried manually cranking them down to the right position and when i play with the switch they " click " and eventually go back to the reverse position. Does anybody have any idea whats going on or has anybody even heard of this?! Thank you very much,
Chris
Good luck !!
