What are these codes???
Old Aug 19, 2007 | 11:28 PM
sacstyl's Avatar
sacstyl
Default What are these codes???
PO705 AND P112. Can i do the repairs myself.
Old Aug 20, 2007 | 02:26 AM
RedRiderZR1's Avatar
RedRiderZR1
Code List
http://www.stengel.net/diccodes.htm
P0705 Transmission Range Switch Circuit (A/T)
I'm guessing P112 is P0112. If so,
P0112 Intake Air Temp (IAT) Sensor Circuit Low Voltage
As far as you doing it yourself. Depends on how comfortable you feel doing it. Lots of people on here to help.
Old Aug 20, 2007 | 11:29 AM
sacstyl's Avatar
sacstyl
TTT Is the AT circuit internal or external.
Old Aug 20, 2007 | 11:51 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yours is a 99 so,,,,I believe that the IAT is located in the plastic air bridge that connects the MAF to the TB. I believe 2000 (maybe 2001) and up changed the loctaion of the IAT to inside the MAF housing. its easy to figure out. Look for a small black sensor sticking out the drivers side of the air bridge. If you cant find it, its inside the MAF..
The ones installed on the bridge get damage easily. check the cobbector, wires and sensor its self.
bc
Old Aug 20, 2007 | 01:20 PM
sacstyl's Avatar
sacstyl
Thanx BILL, Anybody know about the tranny circuit.
Old Aug 20, 2007 | 03:24 PM
sacstyl's Avatar
sacstyl
ttt
Old Aug 20, 2007 | 08:15 PM
sacstyl's Avatar
sacstyl
ttt
Old Aug 20, 2007 | 10:04 PM
RedRiderZR1
In regards to P0705 here is some reading for you.
http://www.gearchatter.com/viewpost14060.php
To What are these codes???
