View Poll Results: What side of the pilot bearing should be facing out away from crank?
Flat side out
21.43%
Chamfered side out
78.57%
Voters: 14. You may not vote on this poll
Pilot Bearing Install ???
Old Aug 20, 2007 | 01:07 AM
2004SpiralGrey's Avatar
2004SpiralGrey
Default Pilot Bearing Install ???
Flat side out
or
Chamfered side out ???
Is there a difference and what could happen if it went in wrong?
Thanks,
John
Old Aug 20, 2007 | 07:02 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Do you have the old one for comparison? Do you have a photo of the one in question?
Old Aug 20, 2007 | 07:37 AM
Patches's Avatar
Patches
Here's one we installed in a buddy's '01 coupe.
The stock one before removal. The radiused end is exposed so the driveshaft end can slide in without resistance.
Installed
Old Aug 20, 2007 | 08:14 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
I'm the first vote and I voted chamfered or radiused side out for ease of assembly with the driveshaft assy, just as Patches mentioned.
Do I win???
Old Aug 20, 2007 | 10:42 AM
2004SpiralGrey
I was looking at other threads and noticed some said flat side out...so i was confused a little. Also on Dope's write up for drivetrain removal it also states flat side out.
Old Aug 20, 2007 | 12:38 PM
Patches's Avatar
Patches
I can argue for either orientation. The stock setup we found on my buddy's car made it easier to slide the shaft in if it's slightly out of alignment, which is often the case. The opposite positioning might allow easier extraction if you think about how the puller fingers might get a better grip on the radius. Here's what our's looked like after yanking the stock bearing out.
Old Aug 20, 2007 | 07:51 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
my uncle spun a pilot bearing installer/clutch alignment tool on the lathe, makes the install a snap
chamfer out
Old Apr 27, 2018 | 08:28 PM
Georgies's Avatar
Georgies
chamfer out
Do you have a pic of that tool? Id like to make my own as well.
Old Apr 27, 2018 | 11:18 PM
Moved to C5 Tech.
Old Apr 28, 2018 | 08:30 AM
vettenuts's Avatar
vettenuts
Wonder how easy it is to remove later if the chamfered side faces forward? I am thinking not too easy.
Old Apr 28, 2018 | 05:25 PM
Georgies's Avatar
Georgies
To Pilot Bearing Install ???
