7° or 10° valve locks?
Old Aug 20, 2007 | 07:39 AM
Eike's Avatar
Eike
Default 7° or 10° valve locks?
Does the C5 has 7° or 10° single grove valve locks?
Does the C5 has 8 mm valve schafts?
I need locks for my C4 AFR heads and am wondering if the stock C5 locks would fit ...
best wishes
Eike
Old Aug 20, 2007 | 11:43 AM
vettenuts's Avatar
vettenuts
7 degree 8 mm, don't think they will fit.
Old Aug 20, 2007 | 12:43 PM
Eike's Avatar
Eike
The AFR valves I have are 8 mm and I need 7° 1-grove locks so why don't you think they will fit?
Old Aug 20, 2007 | 01:35 PM
vettenuts's Avatar
vettenuts
Didn't know the C4 heads were 8mm, figured standard small block valve. They are 8mm bead lock.
Old Aug 20, 2007 | 01:38 PM
Eike's Avatar
Eike
Stock C4 heads have 11/32 valves ... the new AFR Eliminator heads have 8 mm valves
Old Aug 21, 2007 | 06:00 AM
vettenuts's Avatar
vettenuts
Probably the best thing to do is to PM Tony Mamo, I am not sure and don't want to give you bad information, he will know without a doubt what you can use and will fit.
To 7° or 10° valve locks?
