99 Front Alignment settings......
Old Aug 20, 2007 | 06:07 PM
LT1vette's Avatar
LT1vette
Default 99 Front Alignment settings......
Does anyone have some settings for the front that DON"T wear the inside off the tires. The car still has "stock factory" settings....
Driven on the street mainly, but there must be a less agressive camber setting to stop the wear on the insides of the tires......
TIA
Old Aug 20, 2007 | 07:39 PM
TEXHAWK0's Avatar
TEXHAWK0
I think you are going to have to be close to zero camber before you will not see some inside tire wear on tires as wide as on the Corvette.
I decreased mine to about -1/8 deg camber before the wear was acceptable for the street. On the Z06, mine came from the factory with over 1 deg negative camber, and it was chewing up the inside edge.
