I have a 2000 LSI with stock ported TB. I want to install an LS6 Cam and LS6 intake that I already have. I will be doing a new LS6 oil pump also. Do I need to change the injectors and fuel rails? I can get 28.8's with fuel rails off a Caddy CTS-V. Do I need different push rods or springs?
PM'S please.
If you are going to break into the engine I would recommend going with a bigger cam than an LS6 cam. Might as well get a bigger HP and torque upgrade if you're gonna do all that work.
What about the injectors, pushrods and springs?
Which Cam would you recommend?
Don't bother with the injectors unless the 28.8's are REALLY cheap. Keep your stock fuel rails. Yes you ABSOLUTELY MUST change your springs, and I would highly advise changing the pushrods too. Do you have an A4 or M6?
Give JP a call: 813-628-0080 & he can go over all the pro's & con's and recomend the best cam grind for your A4 as well as when you need different springs, etc. You are very close so a short drive to the shop for a tour & to talk to the techs in person is also advised.
You have done work for me in the past. I will call JP.
The 2000 has the smaller injectors; but most of the guys indicate they are fine below about 400 RWHP. So should be no problem if you only plan on a cam and intake.
The problem with the LS6 cam is that it will not provide much more torque below 4000-4500 than your current cam, it's gains are mostly top-end. A nice little Comp cam can easily add 20-25 ft-lb down where you can really feel it on the street. $300 well spent in my opinion. You can use the LS6 springs as long as you don't get too big a cam, 0.560 or so, and don't set the rev limiter too high. Lingenfelter uses them for their 0.580 cam.
DG
Very good advice DG, and we just announced a special we have going w/Comp Cams to do an entire package with everything for under $2000. See the RevXtreme cam special thread.
I've read a few threads that suggest that rockers are a good idea as well...Apparently, when older, the needle bearings like to fall out? Just a thought...
When I had the stock injectors (26.2#) and making 340 rwhp, my injector duty cycle was 85-87%. "They" say it's not supposed to be over 80%. I changed injectors to 28.8# when I put an LS6 intake on. I added about 12-15 hp and injector duty cycle is now 72% with the 28.8s.
Send them to Harland Sharp and they will install bearing retainers, theyre great. There is NO possible way for the HS modded rockers to puke bearings.
2000C5, I certainly can't really argue with that logic. It would seem that no more than 80% injector DC would be good.
I certainly don't want to give bad advice.
I was quoting a few of the guys here who used the smaller injectors with modded motors and saw no problem; claiming the injectors could actually go to 100% for short periods with no issues.
Also, when I had my car tuned at a very respected Dallas shop, he made the comment that my 365RWHP was no problem with the small injectors "They are okay up to around 400" he said.
I've had no problems for the last two years, but now you've got me thinking......
If you're doing all that work don't waste your time w/ an LS6 cam... it won't be that different, esp w/o the heads.
You figure a bolt on lS1 makes 330-340 rwhp and a bolton LS6 makes 380-390 rwhp. But that's w/ the LS6 heads too. So just the cam and manifold won't get you much at all.
As said, there are many great cams out there that will give you stock drivability w/ a nice power increase. Something like a 224/228 cam would be great.
Yes, the oem rockers have been know to puke their needle bearings. When I put my cam in I had 70k on mine so I chose to get the new Yella Terra Ultralights, however, another great option is to send your stockers out to Harland sharp and have them modified w/ new trunions. It makes them far more stout and no worry of needle bearings ever again. I went w/ the YTs because they were on sale for < $400 at the time whe nthe HS modified stockers are $250ish.
