Oil Pressure Sending Unit
thank you in advance
Steve
Mark
Steve
Ricky
http://forums.corvetteforum.com/show...ght=change+oil
http://forums.corvetteforum.com/c5-t...ling-pics.html
1' 1/16th oil pressure socket,
universal and a 12' 3/8 drive extension
coat hanger with a little hook at the end, gets the connector off
1 piece of coax cable with the connector end, fits into the end of the new sender,taped on with masking tape, makes install easier. I used masking tape because it's easy to get off, you can use duct tape, but don't get too crazy..you cant leave any on the sender...
long offset hemostats will help re-install connector
takes between 15 min and an hour and a half, depending how lucky you are...
do not drop it! you probably wont get it back...i tied a piece of light string on it, just in case...
here is a video showing it being done:
This beats pulling the intake off...removing the PCV hose gives you more room to work...
Of all the place's they could have put that sending unit!...i wonder about GM engineer's sometimes...
PS...To bad about the C7R's in the 'United Sports Car Series Racing' at VIR this weekend...They were kicking butt this season until they hobbled them with added weight, smaller restricter and less down-force...they made them the slowest cars in GTLM...overcompensation by the officials
