strange problem???
Old Aug 25, 2007 | 03:18 AM
wettvette's Avatar
wettvette
Default strange problem???
the car dic resets its self randomly. For example i have it reading in kph rather then mph and it will change back to mph on its own as well as reset the gas milage and average etc. sometimes when i have restarted the car also i keep getting an engine code randomly when im giving it a bit code is PO200
Old Aug 25, 2007 | 12:17 PM
69's Avatar
69
Cruise-In VI Veteran
Hello, I'll try and point you in the right direction.
DTC P0200
Circuit Description
The control module enables the appropriate fuel injector on the intake stroke for each cylinder. Ignition voltage is supplied to the fuel injectors. The control module controls each fuel injector by grounding the control circuit via a solid state device called a driver. The control module monitors the status of each driver. If the control module detects an incorrect voltage for the commanded state of the driver, a fuel injector control DTC sets.
Conditions for Running the DTC
The engine speed is more than 400 RPM.
The ignition voltage is between 6-18 volts.
Conditions for Setting the DTC
The PCM detects an incorrect voltage on a fuel injector control circuit.
The condition exists for 5 seconds.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Performing the Fuel Injector Coil test may help to isolate an intermittent condition. Refer to Fuel Injector Coil Test .
For an intermittent condition, refer to Intermittent Conditions .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step tests for voltage at the fuel injector harness connector. The INJ fuse supplies power to the coil side of the fuel injector harness connector. If the fuse is open, a short to ground on the fuel injector B+ supply circuit is indicated. The INJ fuse also supplies voltage to the ignition coils. If the fuse is open, inspect the circuits to the ignition coils for a short to ground.
This step verifies that the PCM is able to control the fuel injector. If the test lamp blinks, then the PCM and the wiring are OK.
This step tests if a ground is constantly being applied to the fuel injector.
Fuel Injector Circuit Check Step
Action
Yes
No
Schematic Reference: Engine Controls Schematics
1
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Use a scan tool in order to clear the DTCs.
Idle the engine at the normal operating temperature.
Use a scan tool in order to monitor the misfire current counters.
Are any of the misfire current counters incrementing?
Go to Step 4
Go to Step 3
3
Observe the Freeze Frame and/or Failure Records data for this DTC.
Turn OFF the ignition for 30 seconds.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC, as specified in the supporting text or as close as possible to the Freeze Frame and/or Failure records data that you observed.
Does the DTC fail this ignition?
Go to Step 4
Go to Diagnostic Aids
4
Turn OFF the ignition.
Disconnect the appropriate harness connector of the fuel injector.
Turn ON the ignition, with the engine OFF.
Probe the ignition voltage circuit of the fuel injector with a test lamp connected to a good ground.
Does the test lamp illuminate?
Go to Step 5
Go to Step 11
5
Connect the fuel injector test lamp J 34730-2C between the control circuit and the ignition voltage circuit of the fuel injector harness connector.
Start the engine.
Does the test lamp blink?
Go to Step 9
Go to Step 6
6
Does the test lamp remain illuminated at all times?
Go to Step 8
Go to Step 7
7
Test the control circuit of the fuel injector for a short to voltage or for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 14
Go to Step 10
8
Test the control circuit of the fuel injector for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 14
Go to Step 13
9
Inspect for poor connections at the harness connector of the fuel injector. Refer to Testing for Intermittent and Poor Connections and Repairing Connector Terminals in Wiring Systems.
Go to Step 14
Go to Step 12
10
Inspect for poor connections at the harness connector of the PCM. Refer to Testing for Intermittent and Poor Connections and Repairing Connector Terminals in Wiring Systems.
Go to Step 14
Go to Step 13
11
Important
The INJ fuse also supplies voltage to the ignition coil modules. If the fuse is open, inspect all related circuits for a short to ground.
Repair the ignition voltage circuit of the fuel injector for an open or for a short to ground. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 14
12
Replace the fuel injector. Refer to Fuel Injector Replacement .
Did you complete the replacement?
Go to Step 14
13
Replace the PCM. Refer to Powertrain Control Module (PCM) Replacement .
Go to Step 14
14
Start the engine.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run and pass?
Go to Step 15
Go to Step 2
15
Use a scan tool in order to observe the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Old Aug 25, 2007 | 12:26 PM
69's Avatar
69
Regarding the Speed "0" issue, use the the owners manual to re-set the memory settings in your car and post back if you have a failure again.
K
Old Aug 25, 2007 | 05:57 PM
wettvette's Avatar
wettvette
K
could the two problems be related some how. im not very clued up when it comes to this sort of stuff
To strange problem???
