LS2 timing chain direct swap?
Old Aug 26, 2007 | 03:47 PM
rustyguns's Avatar
rustyguns
Default LS2 timing chain direct swap?
ls2 timing chain direct swap on an ls6? or does it need something?
Old Aug 26, 2007 | 03:50 PM
rustyguns's Avatar
rustyguns
ttt
Old Aug 26, 2007 | 04:31 PM
rustyguns's Avatar
rustyguns
ttt
vettenuts's Avatar
vettenuts
Yes, direct swap. As a matter of fact, if you order a new LS6 chain you will actually get the LS2 chain.
Old Aug 26, 2007 | 04:33 PM
spiral04's Avatar
spiral04
Yes, I believe so. LAPD is doing mine right now. I saw my old chain in a bag and they looked the same. I believe the LS2 is just a stronger chain.
Old Aug 26, 2007 | 05:53 PM
chummmma's Avatar
chummmma
ls2 chain is a tad bit wider then the stock ls1 gear set.. its not a perfect fit but it works.
Old Aug 26, 2007 | 05:59 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
vn's is correct
Old Aug 26, 2007 | 08:04 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by Steve Doten
vn's is correct
Steve,
Does the LS2, or LS7 use a timing chain tensioner or "damper"?
Old Aug 27, 2007 | 07:43 AM
see5's Avatar
see5
Originally Posted by LoneStarFRC
Steve,
Yes, both use dampener and you can retrofit on a LS2/6 but it is different part number and you may have to drill and tap. Some blocks had holes some didn't.
Old Aug 27, 2007 | 09:13 AM
LoneStarFRC
Thanks.
To LS2 timing chain direct swap?
