Best Brake Fluid?
Old Aug 26, 2007 | 07:20 PM
Corvette Don's Avatar
Corvette Don
Default Best Brake Fluid?
Ok I know the cap says DOT 3 but what about DOT 4? Synthetic ok?? I am using Valvoline synthetic brake fluid right now and I dont think I am too happy with it plus a instructor @ Hallett (autocross track) yesterday says not to really use syn unless it calls for it but I would like to get your opnion on it. Whats the good stuff?
Old Aug 26, 2007 | 07:32 PM
AU N EGL's Avatar
AU N EGL
For track use chose a brake fluid that has a WET not dry boiling point as close to if not above 400*
BRAKE FLUID COMPARISON CHART
Brand Wet Boiling Point Dry Boiling Point
Castrol SRF 518°F 590°F
Motul RBF600 420°F 593°F
Wilwood EXP 600 417°F 626°F
AP-600 410°F 572°F
ATE-Super Blue 392°F 536°F
Valvoline 333°F 513°F
Castrol LMA 311°F 446°F
Ford HD 290°F 550°F
Wilwood 570 284°F 570°F
PFC-Z rated 284°F 550°F
AP-550 284°F 550°F
Old Aug 26, 2007 | 07:40 PM
Corvette Don
AP-600 410°F 572°F
Ford HD 290°F 550°F
AP-550 284°F 550°F
Ahh, any idea where to get that high end stuff??
Old Aug 26, 2007 | 07:41 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Wholly crap, I just looked that Castrol SRF up....$80 a qt!
I'll stick with the Motul RBF.
Old Aug 26, 2007 | 08:03 PM
curtbriggs's Avatar
curtbriggs
Default Brake Fluids
I copied this from somewhere. Thank you to the authors.
Don't use Silicone, the anti-skid system makes it bubble and will give you a soft pedal.
I use ATE Super Blue or ATE type 200, the only difference is color so you can see the new fluid during a flush.
Cheers, Curt
Brake Fluids
Thanks to Dave Zeckhausen :
Lets look at what the DOT ratings mean. The table below shows the MINIMUM wet and dry boiling points for DOT 2, 3, 4, and 5 brake fluid in degrees fahrenheit.
DOT 2 DOT 3 DOT 4 DOT 5
Dry Boiling point 374 401 446 500
Wet boiling point 284 311 356
The DOT 2 spec is for drum brakes and is obsolete. If you have any DOT 2 in your garage, throw it away! DOT 5 is for silicone brake fluid. Silicone brake fluid (DOT 5) should be avoided because it is not compatible with regular brake fluid, it is hard to pour without introducing bubbles and thus results in soft pedal feel, and moisture still gets into your system and will pool in low areas like your calipers and encourage rapid corrosion. STAY AWAY!
That leaves DOT 3 and DOT 4 fluids. These fluids are compatible with each other and may be interchanged or mixed with no ill effects.
Let's look at some popular brake fluids and their boiling points:
Fluid DRY WET
Castrol LMA DOT 3/4 446 311
Ford Heavy Duty DOT 3 550 290
ATE Super Blue Racing 536 392
ATE TYP 200 536 392
Motul Racing 600 585 421
Castrol SRF 590 518
Performance Friction 550 284
Castrol LMA is very good at rejecting moisture and may be kept in your brake system for a couple years. The LMA stands for "Low Moisture Activity". This is the minimum quality stuff that I would use in my Impala. It comes in plastic containers which do not have a long shelf life. Don't buy lots of this stuff at a time because moisture can make its way through the plastic containers.
Ford Heavy Duty DOT 3 is VERY inexpensive and is popular among racers because of its excellent dry boiling point. It absorbs moisture quickly, but the racers don't care since they change their fluid frequently. Comes in metal cans so it may be stored. I would not use this in my Impala for the street.
ATE Super Blue Racing and ATE TYP 200 are the same brake fluid in two different colors (blue and amber, respectively). BMW recommends this brake fluid for their street cars because it, like Castrol LMA, absorbs moisture very slowly. The advantage over LMA is that ATE has a much better wet boiling point. You can put this stuff in your car and forget about it for a long time. An excellent choice for a weekend track car which also sees regular street duty. Comes in metal cans. This is what I use in all my street cars.
Motul Racing 600 is a very exotic and expensive synthetic fluid with high wet and dry boiling points. I use this exclusively in my race cars. Too expensive for the street and requires frequent changing due to its hygroscopic nature. Sold in plastic bottles. It is not suitable for the street because it absorbs moisture quickly.
Castrol SRF is a hyper-exotic and hyper-expensive brake fluid that is generally used by wealthy Porsche owners at track events. I've seen prices of $78 per liter for this stuff. Sold in metal cans. I can't afford this stuff!
Performance Friction High Performance DOT 3 has a good dry boiling point but a crummy wet boiling point. It comes in metal cans which is good for shelf life and sells for $7.87 per 16 ounce container. If you are even considering this fluid, I would go with the cheaper Ford Heavy Duty DOT 3. In either case, change this fluid frequently due to the poor wet boiling point.
Thanks to Leigh Smith for the following information on the impact of moisture content in brake fluid :
The amount of moisture in brake fluid definitely affects its performance. The big problem is it is absorbs moisture quickly. Over a relatively short period of time brake fluid will absorb moisture from the air. SAE field tests have shown that the average one year old car has 2% moisture in the fluid. A random test of vehicles in the U.S. showed an average water content of 2.6% for vehicles with an average age of 8 years. And 25% of these vehicles had water content greater than 4%.
As water content in brake fluid increases over time, the boiling point decreases. Fluid with a reduced boiling point (or high water content) can create vapor by boiling in the caliper, or wheel cylinder. The result is sudden brake failure. And water in the brake fluid can contribute to corrosion of parts such as steel pistons and ABS modulators.
The end result is even though DOT 3 fluid is "rated" at greater than 401oF, in the typical 3 to 4 year old car with 3 to 4% moisture content, it could boil under 300oF. And if it has got more than 4% moisture, you may as well be running straight water!
Moral: Flush your brake fluid every year or so. But only if you would like it to work well scarcely an inch away from those toasty 500oF rotors on your SHO during a couple of hard stops! Or would you rather have a squishy pedal?
Old Aug 26, 2007 | 08:12 PM
Corvette Don
curtbriggs, thanks for the post, What should I get for some decent street fluid that I can get local?? Should I just get the Ford DOT 3 or stick with the sys val fluid I have now?
Old Aug 26, 2007 | 08:14 PM
AU N EGL's Avatar
AU N EGL
If you can find it. Motul sources are drying up in the States.
Brembo makes a Brake fluid as well and comparable to the Motul. I do not have the WET and DRY boiling points so I have not added it to the chart,.
I use Castrol SRF in the race car, Castrol LMA in the wifes vette and my tow vehical
GOOD mail order RACE shops carry these fluids. PFC.com ( forum Sponsor ) has Super Blue & Gold I believe.
cdoc.com is a race mail order place and carries several of the above.
Normally two bottles to fully flush. But get three so you have one full bottle extra
Old Aug 26, 2007 | 09:16 PM
thetorch's Avatar
thetorch
I used Motul RBF600 for 3 1/2 years and always sourced it from cyclepages.com. Good price and always available.
I recently switched to ProSpeed GS610 sourced from OGracing.com. Same price as the Motul with better boiling points. A great fluid so far.
Old Aug 26, 2007 | 10:45 PM
Corvette Don
What about ATE SUPER BLUE brake fluid? http://www.ogracing.com/eshop/itemde...12&showbrake=1
Old Aug 26, 2007 | 10:50 PM
rws.1's Avatar
rws.1
Valvoline Synpower DOT 3 & DOT 4 brake fluid.
available widely....
It is a borated ester which gives it higher boiling point and less tendency to absorb water
Old Aug 26, 2007 | 11:08 PM
thetorch's Avatar
thetorch
Both it and the Ate Gold are decent fluids, especially if the car is mostly street driven. If the car is open tracked you could benefit from one of the better fluids. e.g. Motul RBF600, Motul RBF660, Quadriga Motorsports (ProSpeed) GS610, Castrol SRF, etc.
See the following link for some additional information:
http://www.quadrigamotorsports.com/C...ke_Fluids.html
Old Aug 26, 2007 | 11:51 PM
Secret237's Avatar
Secret237
I use the Castrol GT LMA because I don't race my car (much) and I think it's better for my brake system cause it's based on Vegtable oils.
Good post on fluids !!
Old Aug 27, 2007 | 02:51 PM
BrianG01's Avatar
BrianG01
I use prestone dot 4 synthetic for my clutch and brakes. Its pretty cheap and available locally....
works great so far
To Best Brake Fluid?
