Experts Please Chime in: Headlight Motor
Old Aug 26, 2007 | 11:58 PM
RL Vetteman's Avatar
RL Vetteman
Default Experts Please Chime in: Headlight Motor
A few days ago I heard the machine gun sound from the passenger headlight motor, and I went to drive this morning and the battery was damn near dead. Is my motor toast at this point, because I was getting ready to order the kit to replace the gear and I would rather fix this in one shot. My guess is is that the motor is drawing current and draining the battery, what do you say?
Old Aug 27, 2007 | 02:32 AM
DeeGee's Avatar
DeeGee
I wouldn't have thought the motor would be killing the battery and it may just be a coincidence. Even with stripped gears the motor runs on for 10 secs max and then shuts off. You probably have another problem. How old is the battery? The OEMs are reknowned for early failures.
Bill Curlee, the Forum electrics guru posted this How To to troubleshoot current draw. It should help you track down the problem
http://forums.corvetteforum.com/show...rent+draw+test
Old Aug 28, 2007 | 03:12 AM
RL Vetteman
Thanks for the reply, I had the battery tested today and it only measured 10Volts, so it is definitely bad. May be a coincidence with the headlight motor, but I will replace the battery and monitor the situation. I bought the car 2 yrs ago with an OEM battery, but I have no idea how old it is. Do you or anyone know how to tell how old the battery is via S/N of the battery? It is the 7yr battery, and in the desert, batteries generally don't last past 3yrs.
To Experts Please Chime in: Headlight Motor
