Suspension Question-Stabilizer Bar
Old Aug 27, 2007 | 09:06 AM
richieice's Avatar
richieice
Default Suspension Question-Stabilizer Bar
I have a 98 convert C5 with no special suspension package. I have noticed some take-off shops on line sell Z06 suspension parts. Basically, I can grab a set (Front/Rear) Stabilizer Bars from about $100.
Question is, will I notice any difference in handeling? Also, will my car need to be re-aligned?
I already upgraded the stabilizer links to the metal ones and the car feels great. Not sure if I should go through the trouble/money to upgrage the Stabilizer Bars?
Old Aug 27, 2007 | 09:15 AM
WKMCD's Avatar
WKMCD
I run Z06 springs, sway bars and Bilstein Sports on my 98 vert. I had the bars and Bilstiens before I added the springs. It was a major improvement over stock but when I added the springs the suspension became much more balanced without being harsh at all.
Well worth it.
Old Aug 27, 2007 | 09:17 AM
Solofast's Avatar
Solofast
Do it...
For that kind of price it is cheap, and they won't be around forever..
Yes the springs will help even more, but I would get the bars while you can..
Old Aug 27, 2007 | 09:19 AM
LoneStarFRC's Avatar
LoneStarFRC
If you can get a pair of Z06 anti-roll bars for $100 or so, that is a good deal.
Yes, you will notice a big difference in handling. A difference you'll like.
No, you will not need re-alignment.
HTH
PS Don't forget new bushings.
Old Aug 27, 2007 | 10:00 AM
robvuk's Avatar
robvuk
I put Z06 bars and shocks on my base coupe. Big improvement even without the springs. Noticeably less body roll and longer tire life at the track. Outside edges don't wear off nearly as fast from all the body roll. No alignment necessary.
Old Aug 27, 2007 | 12:14 PM
jovette's Avatar
jovette
I did the same thing to my 2000 coupe. Love the improvement in handling / cornering and the ride is still great.
Old Aug 27, 2007 | 04:17 PM
richieice's Avatar
richieice
Many thanks to all that got back to me. Turns out the new bushings are included. Looking forward to swaping them out for the new ones.
Thanks again!
Old Aug 27, 2007 | 04:52 PM
LoneStarFRC
Thanks again!
Come back with your impressions when finished.
Old Aug 31, 2007 | 09:14 PM
Nowayman's Avatar
Nowayman
Default st of swaybars available for the C5
Here is a list of swaybars available for the C5. yes, The C6 fit the C5. In 30 minutes, I installed a C6 Z51 bar (larger than the Z06 C5 bar and much less expensive - see Gene Culley) and I love it. Im running C6 Z06 shocks with 20s in the rear and 19s out front.
Rear in. mm
C5 Base 0.75 19.0
C5 FE3 1997-99 1.00 25.4
C5 FE3 2000-04 0.93 23.6
C5 Z06 0.93 23.6
C6 Z51 1.00 25.4
C6 Z06 1.14 28.8
Front in. mm
C5 Base 0.91 23.0
C5 FE3 2000-04 1.13 28.6
C5 Z06 1.18 30.0
C6 Z51 1.22 30.9
C5 Hotchkis 1.25 31.8
C5 T1 1.51 38.4
To Suspension Question-Stabilizer Bar
