AC belt tensioner
Old Aug 31, 2007 | 04:19 PM
bowtiebubba's Avatar
bowtiebubba
Default AC belt tensioner
I just changed the ac belt(lower belt). After changed i got under the car just to check everything and the ac belt is sticking out about a 1/8 of an inch over the end of the lower tensioner while running.I kind of eyed up all the other pulleys and it looks to me like the tensioner pulley sets in to far.
Is this normal? Oh,and now i have the little squeak,didnt squeak before i changed the belt. I dont know if this makes a difference,but,i had a H/C swap about 6 months ago. Thanks,guys
Old Aug 31, 2007 | 08:23 PM
bowtiebubba
ttt
Old Aug 31, 2007 | 10:33 PM
vettenuts's Avatar
vettenuts
No, they should all line up, the A/C pulley, the crank pulley the tensioner and the idler. Sounds like the tensioner may have an issue, does it only rotate when you remove tension to get the belt off? The main tensioner on my Pontiac had a lot of slop in it and I had to replace it.
To AC belt tensioner
