tire pressure sensor
Old Aug 27, 2007 | 10:10 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Default tire pressure sensor
I have a sensor that will occasionally read 8psi and then will give a different reading after cycling the ignition.
What is going on here? What is the life expectancy on a tire sensor?
Old Aug 28, 2007 | 12:16 AM
Corvette Don's Avatar
Corvette Don
If you have a 2000 or older the sensors are rated at 7yrs or 100,000 miles, your sensors battery is prob on its way out. You can try to retrain the sensors w/ a magnet to see if that fixes it. I am sending you a pm.
Old Aug 28, 2007 | 12:54 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
ok sounds good when i can ill ask for your service
im a 2000 with 100k so sounds right
To tire pressure sensor
