'check engine" light
Old Aug 28, 2007 | 01:44 AM
c5-pewter's Avatar
c5-pewter
c5-pewter
St. Jude Donor '08
Default 'check engine" light
Advice please!!
Have searched this secton for an answer, but to no avail. Installied a Skip Shift Eliminator and another Clutch, and for some reason that I cannot fathom, the "check engine light" has come on. However, no codes are flashing. Additionally, after a few miles of driving the speedometer / odometer have quit as well. Yes, the drive train was dropped (to the floor) with everything disconnected. Any clues?????
Any hint would help, and thanks.
Regards, GRT
Old Aug 28, 2007 | 08:54 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
No sure what you mean by no codes are flashing, they just don't appear automatically.
If the CE light is on then there should be codes, on the DIC controls press and hold options and then press Fuel 4 times while still holding the options button you must do this quickly. A message will appear saying "Diagonstics" then it will automatically read off the codes.
Old Aug 28, 2007 | 09:53 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep Is the CEL flashing or on steady??
BC
Old Aug 28, 2007 | 12:22 PM
c5-pewter's Avatar
c5-pewter
c5-pewter
St. Jude Donor '08
Default Cel
Thanks for your quick reply Stephen.
By "no codes flashing" I meant that no codes showed up on the computer readout beneath the speedometer. I shall try your recommendation.
Regards, GRT
Old Aug 28, 2007 | 12:28 PM
c5-pewter's Avatar
c5-pewter
c5-pewter
St. Jude Donor '08
BC
Hi Bill,
Nice to hear from you again! (recent advice on c6 shocks) The CEL is on steady. When it is turned off, it comes back on within a short time. Thanks.
Thanks, GRT
To 'check engine" light
