service column lock???????
Old Aug 28, 2007 | 11:32 AM
dugsc5's Avatar
dugsc5
Default service column lock???????
I have a 98 coupe. Went to take off yesterday and the DIC had a warning message "service column lock" and "pull key, wait 10 secs" does anyone know what they mean. Also, when I put it in gear and start to move the whole car just cuts off. What is my major malfunction goin on here? Thanks for any help
Old Aug 28, 2007 | 12:02 PM
timemender's Avatar
timemender
Read the sticky at the top of C5 Tech
Old Aug 28, 2007 | 12:25 PM
dougbfresh's Avatar
dougbfresh
How could you be a member since 04' and not know about this? Or about the SEARCH function?
Old Aug 28, 2007 | 12:35 PM
TEXHAWK0's Avatar
TEXHAWK0
There are no details about your car in your profile, but you either have a column lock actuator failure, or if you have had the GM recall performed, a possible Harness K relay failure.
If the BCM thinks the column is locked, or it cannot determine the actuator position, it will send a signal to the PCM to cut the fuel when you drive over 2-3 mph. You need to do a little checking to determine if your car has had a recall performed on the column lock actuator for us to pinpoint the problem.
Old Aug 28, 2007 | 01:31 PM
jovette's Avatar
jovette
Both pretty good questions. Hard to believe...............
To service column lock???????
