Help! Can't Access Fuel Cap
Old Aug 29, 2007 | 07:26 PM
scondo's Avatar
scondo
Default Help! Can't Access Fuel Cap
I just went to fill up my '00 Coupe and when I hit the fuel door release, nothing happened. Has anyone else experienced this? Am I looking at an expensive repair (I think I already know the answer to that one)? And is there a way to access the gas cap in the meantime?
Any guidance you can give will be greatly appreciated.
--Scondo
Old Aug 29, 2007 | 07:29 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
theres a pull tab near the gas door on the inside of the car for a quick fix.
Old Aug 29, 2007 | 08:44 PM
65GGvert's Avatar
65GGvert
If the problem is electrical, the pull tab and cable will get the door open for you. It's inside, behind the driver's seat, over the wheel well (maybe tucked under the carpet) It shouldn't be too expensive either way. There's only a button, a solenoid and a tab that pulls back to open the door. It could be sticking, the button could have come unplugged in the console, or maybe power to the button is lost. None of the parts are expensive. Some have had luck after opening the door lubricating the tab that slides into the solenoid to free it up.
Old Aug 30, 2007 | 01:19 AM
PierEagle's Avatar
PierEagle
Try this. Have someone tap a couple of times on the fuel door button while you bump the door with your hand. What you are trying to do is take pressure off the releasing pin at the door.
Old Aug 30, 2007 | 01:23 AM
DeeGee's Avatar
DeeGee
Did you check the fuse?
It's #32 on the instrument panel fuse block (passenger footwell)
If so, once you have it open a good lube may fix it. If not I'd be checking the power at the flap.
Old Aug 30, 2007 | 11:35 AM
44mag's Avatar
44mag
Old Aug 30, 2007 | 06:14 PM
BrianG01's Avatar
BrianG01
Its either fuse 32 or 28 I forget which and I think it is a 10amp micro fuse. Mine blew when I removed my console rubbed through a wire grounding the system out.
Does your trunk release and foglight buttons work? If so, it may not be the fuse because all 3 of mine died when the fuse blew and worked fine after I fixed the short and replaced the fuse.
Old Aug 30, 2007 | 07:35 PM
hotwheels57's Avatar
hotwheels57
Mine used to stick occasionally. Some have reported rust in the plunger under the cover. Open it with the pull tab and then lightly lubricate it with white lithium grease. Actuate the plunger several times and see if that works for you...did for mine.
Old Sep 10, 2007 | 11:13 PM
skydive120's Avatar
skydive120
Have a similar problem.
The solenoid works fine, the door just will not pop open- tried lub already. If I hit the button and pry on the the aft portion of the fuel filler door it opens right up.
Anyone have this issue?
Chris
To Help! Can't Access Fuel Cap
