MAP Pressure Fluctuates
Old Aug 30, 2007 | 10:46 PM
95BlueBomber's Avatar
95BlueBomber
Default MAP Pressure Fluctuates
I know this probably belongs in the scan and tune section but nobody responds in there. As title says, I am having an issue at WOT my map pressure is fluctuating, at some points it gets down to 90KPA. The car is a head and cam car, Dart 205's, 224/230 cam. Any ideas?
Old Aug 31, 2007 | 10:45 PM
trk982003's Avatar
trk982003
how do you know what your map is doing at wot?
Old Sep 1, 2007 | 08:33 AM
vettenuts's Avatar
vettenuts
Sounds like an intake restriction. Either the intake itself is not feeding the engine fast enough or your filter/intake tract is at fault. If as the RPM climbs up near redline you are observing a steady drop, you are building vacuum in the intake.
To MAP Pressure Fluctuates
