Pinning the Crank
Old Aug 31, 2007 | 10:38 AM
MYLS6's Avatar
MYLS6
Default Pinning the Crank
been seeing this reference in some posts..did a search found little info on it other then suggestions to do it, but no info on why its done or how to do it. Is this a must on FI cars or is it a highly suggested mod? can someone explain...thanks
Old Aug 31, 2007 | 11:01 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
It is for supercharged engines. The crankshaft pulley is a slip fit with no key way. The additional force required to operate the supercharger (centrifugal or roots type ) will cause the pulley to slip on the crankshaft snout.
Old Aug 31, 2007 | 11:44 AM
MYLS6's Avatar
MYLS6
awe ok got it...thanks for that..is there a write up anywhere on how to do this? Seems like a good idea for me to do this during the D1 install...
Old Aug 31, 2007 | 05:30 PM
vettenuts's Avatar
vettenuts
I have done this on all the cars I have worked on. The damper is an interference fit, the pin won't allow the damper to move relative to the crank snout and back off as a result. The ATI kit works well, but you must have a damper with a 3/16" keyway milled into it. The ATI and Powerbond both have this keyway, not sure on others.
Old Aug 31, 2007 | 07:42 PM
AVB's Avatar
AVB
Contact ECS or A&A and they can sell you a pinning kit for non-keyway or whatever you have..
Or... if you're feelin lucky, post to borrow one one on the FI section and just pick up 1/4" hardened pins.
Arnel
Old Sep 1, 2007 | 12:20 PM
Last C5's Avatar
Last C5
Default HOW? (Thread Infringement)
Do you drill the snout or what? And how is this done?
Old Sep 1, 2007 | 01:10 PM
vettenuts's Avatar
vettenuts
There are two types. The ATI kit drills the crank crosswise and then it is precision reamed. Once done, a 3/16 pin (or optionally two pins) are then put in the hole and the pulley re-installed. This requires the pulley to have a 3/16" keyway milled in it. The other type that AVB was discussing removes the bolt from the pulley and a fixture is installed such that the drilled hole is half in the crank and half in the pulley hub. This is done end wise.
The ATI kit (I used this one) is shown below and the 2nd photo is the kit installed on the crank for drilling (ignore the aluminum foil, that was to keep the chips out). There is one additional advantage to the ATI kit. I use the drill hub to align the timing cover when I do a cam. It slides on and is used to center the front seal. Once the cover it tight, you can slide it off and take your time putting on the damper.
Old Sep 1, 2007 | 01:50 PM
Last C5's Avatar
Last C5
First, my apologies to MYLS6 for infringing on his thread.
And thanks Vettenuts for a great write up. It looks like something I could handle.
Old Sep 1, 2007 | 04:11 PM
vetterlatethannever's Avatar
vetterlatethannever
Good info here!
Old Sep 2, 2007 | 10:25 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If you are using a stock balancer you will need to pin with the ECS or A&A pin kit. You will not be able to pin with the ATI kit if using the stock balancer. I always include the crank pinning when I do a cam job just in case the customer goes FI later.
Old Sep 2, 2007 | 10:59 AM
vetterlatethannever
Old Sep 2, 2007 | 11:29 AM
MYLS6's Avatar
MYLS6
great info here so I can contact ECS or A&A to get this kit/
Old Sep 2, 2007 | 11:57 AM
Cajundude's Avatar
Cajundude
Yep.
Old Sep 2, 2007 | 01:52 PM
vetterlatethannever
Old Sep 2, 2007 | 09:22 PM
vettenuts's Avatar
vettenuts
Correct, unless you want to have a machine shop mill the keyway into the hub. I know someone who has done this. The only disadvantage to the end on kit is re-alignment of the pins should you remove later and then re-install or use a new pulley that is not drilled.
Old Sep 3, 2007 | 08:57 AM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Pin it while you are on the stock shortblock and when you want to replace that then get the crank milled for a keyway that is what I am doing now with my crank.
To Pinning the Crank
