Cam size vs. Smog
Old Aug 31, 2007 | 03:33 PM
thesaad's Avatar
thesaad
Default Cam size vs. Smog
Hey Guys, I am thinking of doing a cam soon and am not sure how big I should go.
I have a 2003 Z06 with kooks headers, hiflow cats, Borla stinger, blackwing intake, and a bbk throttle body that was on the car when I bought it (i think 80mm)
I am looking at several cams right now, but dont know how big I can go and still pass CA smog. I know that the headers will have to be swapped when I smog, but that is not as much work as a cam.
I am looking at G5X2, G5X3, and some thunder racing cams.
I want to have a strong solid idle, and not too much of lope (114, maybe 112 LSA). But I want to get as much hp as I can get from the 4300-6000 range.
What are your recommendations? I was going to wait until I can afford to do heads, but I have a sickness and cant stop shopping for parts. Plus a fiend with a pesky snake wants to play (2006 Viper Vert.). Can I hang with him, considering drivers have same capabilities?
Old Aug 31, 2007 | 03:53 PM
merven's Avatar
merven
The biggest thing with cams and smog is the overlap, between exhaust and intake, a lot of times you can get away with increasing lift which inturn increases volume but when you increase duration you tend to fall out of the smog arena I hope this makes sense to you.
Old Aug 31, 2007 | 04:12 PM
GKE's Avatar
GKE
I am installing a Comp Cams 224/228 114 LSA and it will pass smog, it is within parameters so the shop tells me.
Old Aug 31, 2007 | 04:25 PM
RedRiderZR1's Avatar
RedRiderZR1
Reading all these cam threads and smog it seems if you go below 114 LSA you're getting into the danger zone. I'm sure 112 LSA cams have passed too, but to be safe it seems to stay with 114 LSA cams. Please correct me if I'm wrong on this. Been reading these for awhile in hopes to put a cam in my 99 coupe as well. Cams and Cali smog can be a pain.
Greg
Old Aug 31, 2007 | 04:39 PM
thesaad's Avatar
thesaad
How big of a difference does the LSA make for hp and tq gains?
So which of these cams would you say will give the best gains, while keeping drivability and smogability?
LG Cams
Thunder Racing Cams
Old Aug 31, 2007 | 05:08 PM
Rag-Top Rick's Avatar
Rag-Top Rick
As a general rule, the above mentioned cam is considered the max in Calif and still pass smog!
I`m sure there are tuners that may be able to pass something"a little bigger" but that`s pushing it.
Old Aug 31, 2007 | 05:21 PM
thesaad's Avatar
thesaad
Ahhh, I was hoping to go a little bit bigger
Oh well. How much hp can I expect with a good tund and this cam?
Old Aug 31, 2007 | 05:40 PM
Third Gear's Avatar
Third Gear
The G5X2 or G5X3 might be a little hard to pass here in CA. Besides if you're looking to maximize your midrange power and not a lot of lope then those big cams aren't for you. Something like a TR 224 would give you a great midrange and pass smog no problem.
As for LSA properties: See this - http://www.compcams.com/Technical/FAQ/LSAproperties.asp
It wouldn't hurt to call a speed shop to tell them your goals.
GKE - you should pass if everything is spot on. I've "heard" of larger cams passing but.... I'd like to see the actual smog report......
Old Aug 31, 2007 | 07:07 PM
bbob67's Avatar
bbob67
I did research on this sometime ago as far as the biggest cams that can be installed and still pass Ca. smog. Look at my past threads/posts and you will find some info. There were a couple of Z06's that pulled about 450 rwhp running the LG-G5X1-E emissions cam and AFR heads.
Old Aug 31, 2007 | 07:33 PM
Showdown's Avatar
Showdown
I'm looking for more of a top end cam. Using a kenne bell when they get the smog cert. Would the LS7 cam be good?
LS2 block
Callies rods
Wiseco pistons (right around -28cc dish)
Callies crank
AFR 225 64cc heads (or something with a THICK deck)
8.9-9.0:1cr
clevite bearings
LS6 lifters
Comp 921 springs
Comp pushrods
Cometic .051 MLS gaskets
ECS 8" crank pulley
ARP main and rod studs
ARP head studs (Unless stock deck. Then ARP L19 studs)
Stock 1.7 rockers
Kenne Bell 2.8H 16-18psi
To Cam size vs. Smog
