Remote Key Problem
Old Aug 31, 2007 | 03:41 PM
gtr.guy's Avatar
gtr.guy
8th Gear
Default Remote Key Problem
99 Vette Can someone tell me where to look to get my remote fob working. have new batteries. Must be fuse?
Old Aug 31, 2007 | 04:18 PM
Oldvetter's Avatar
Oldvetter
push and hold both lock and unlock buttons while next to car for 10 seconds or until the horn beeps. This re-synch's the remote.
If this does not work, you must relearn all remotes.
Old Aug 31, 2007 | 04:39 PM
bighank's Avatar
bighank
Default or its as GONNER
I had 2 remotes die on me. New batteries but the fob would loose sync after about 10 minutes. Solution fleebay or elsewhere.
You need one with FCCID AB00216T. A remote from 97-00 ONLY will work on your 99. They aren't CHEAP. I got 3 on fleebay averaging $70 or $80. That was a year ago. Now theyre even MORE expensive. Gene at GMPARTSHOUSE has NEW ones and right now he has em on sale. Don't keep using the key or you will wear out the lock and switch and be worse off than the cost of a remote. Detailed learning instructions are on here several times. BIGHANK
To Remote Key Problem
