Funny Noise from Textraila ??
Old Aug 31, 2007 | 05:11 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Funny Noise from Textraila ??
When I let the clutch out slowly it makes a squeeking/grinding noise. It seems to only do it in first and reverse. It really gets annoying. Does anyone know if this is normal. My brother had a 2001 vette with the Luk Pro Gold clutch in it and he said it made the same noise. Anyone know ? Thanks
Chris
Old Aug 31, 2007 | 05:46 PM
Third Gear's Avatar
Third Gear
Mine chatters some if you let it out too slow (car shakes a little). It should improve as the clutch gets broken in.
Old Aug 31, 2007 | 06:02 PM
Corvette-Chris
St. Jude Donor '08
Yeah I knew they chattered but It doesnt seem like a chatter sound. Its more of a grinding sound
Old Aug 31, 2007 | 06:16 PM
02gt350's Avatar
02gt350
Old Aug 31, 2007 | 07:08 PM
Billdog350's Avatar
Billdog350
My tex makes a squealing/chirping occasionally, sounds almost like a dry bearing. I thought it was the throwout or pilot bearing going at first...but at this point it sounds like a nomal Tex thing. It also shudders if you let it up too slowly or between 900 and 1500rpm.
However, it never slips, loves being "beaten", and grabs perfectly with my ~420rwhp (~500crank hp). It's the nature of the beast, and I'll take it over having clutch problems any day!
Old Aug 31, 2007 | 07:28 PM
Third Gear's Avatar
Third Gear
hmm... now that I think about it I know the sound you're talking about right after you let it out... and it's normal.
Old Sep 1, 2007 | 07:03 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
mine chatters like teeth in the winter unless Im hard on it. If I go easier, it chatters.
Old Sep 1, 2007 | 08:32 AM
Corvette-Chris
St. Jude Donor '08
Well I guess my breakin period is over so Im gonna go beat the hell out of it for the weekend Thanks guys
Old Sep 2, 2007 | 10:47 AM
wango tango's Avatar
wango tango
hydraulics, pilot bearing, or slave needs shimmed if you turned the flywheel.
Old Sep 2, 2007 | 11:30 AM
Corvette-Chris
St. Jude Donor '08
^ Everything is brand new
Old Sep 2, 2007 | 12:21 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Hi Chris, it's normal. If you broke it in, tear that clutch up this weekend! Aftermarket clutches make noise, it is part of the game.
Old Sep 2, 2007 | 12:28 PM
Corvette-Chris
St. Jude Donor '08
Yeah I figured it was Im gonna drive the **** out of it this weekend
Old Sep 2, 2007 | 03:50 PM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
Good idea....
I had the same problem...
My clutch squeeled like a stuck pig..
I called ECS and they said it was normal...Doug asked me if I had in fact hard launched the car which I hadn't...
His recommendation ??
Put it in 4th...rev it up to 4000 rpms and let it slip until the car almost stalls....
No more squeeling after that....clutch is quiet as a mouse now !!
Lesson to be learned I guess is not to drive your vette like a ***** !!!
Old Sep 2, 2007 | 09:30 PM
Corvette-Chris
St. Jude Donor '08
Originally Posted by BUBBAS 01Z06
Good idea....
Well I will sure as hell give that a try !! Thanks
Old Sep 3, 2007 | 04:11 PM
BUBBAS 01Z06
How did ya make out ??????
Old Sep 3, 2007 | 05:08 PM
Corvette-Chris
St. Jude Donor '08
I have the FRC's, washer tank, and coolant tank off because Im painting but I should be done tomorrow if my damn professors dont assign to many assignments. i will difinantly let you know
Old Sep 18, 2007 | 09:15 PM
saw22's Avatar
saw22
HAHA... I read this statement and laughed out loud. This should be me in about a month. Still got about 400 stop/go miles left on my SPEC 3+
Old Sep 18, 2007 | 09:27 PM
Corvette-Chris
St. Jude Donor '08
Oh I tried the method stated by BUBBA to rev it to 4k and slip it. I havent heard the chatter in weeks. You people are good !!!
To Funny Noise from Textraila ??
