Belt busted...HELP
Old Sep 16, 2007 | 02:32 AM
Crewrow's Avatar
Crewrow
Default Belt busted...HELP
So tonight on way home I heard a weird noise on acceleration. Suddently no power steering/heat/battery level dropped and engine temp skyrocketed. Opened hood and there's a belt snapped and frayed. Now question is, Is there only 1 belt? And is it just one I can get at Schucks? I looked at website and it saw this:
Vehicle: 1999 CHEVROLET CORVETTE
Engine: V8 5.7 Liter FI
Serpentine Belt: Poly-V; Alternator And Power Steering
I'm assuming this is what I need?
Old Sep 16, 2007 | 08:01 AM
rws.1's Avatar
rws.1
Any autoparts store.....
AutoZone, Advance, NAPA, PEPBOYS, CARQUEST etc etc
GoodYear GatorBack is the most used here The gator back will set you back $24-$35 depending on wher eyou buy it
At Autozone it's
Part Number: 4060798
Weight: 0.393 lbs.
Note: Poly-V alt & P/S
Unique Gatorback rib design reduces noise and extends life by reducing heat build-up
but GATES and DAYCO are fine buyu the better ones with th elifetime guarantee.
Old Sep 16, 2007 | 08:10 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
There are 2 belts............
Old Sep 16, 2007 | 10:21 AM
road dog's Avatar
road dog
see what caused it to bust before you install a new belt check your crank pully first or that something is not locked up
Old Sep 16, 2007 | 11:49 AM
Cart99's Avatar
Cart99
Old Sep 16, 2007 | 11:56 AM
MagRedConv's Avatar
MagRedConv
You had better take it to the dealership, questioning such simple things lead me to believe that mechanics aren't your forte'
Old Sep 16, 2007 | 12:39 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
At Autozone it's
Weight: 0.393 lbs.
That's good advice... The Goodyear Gatorback, 4060798 is a greta belt. far exceeds the OEM AC Delco
Old Sep 16, 2007 | 12:48 PM
LoneStarFRC's Avatar
LoneStarFRC
Old Sep 16, 2007 | 12:50 PM
rws.1's Avatar
rws.1
yes there are two belts.... but the smaller is only for the Air conditioning...
if he experienced this...Suddently no power steering/heat/battery level dropped and engine temp skyrocketed.
then the broken belt is the one I referenced...
BUT if you point is while there... also get the A/C belt and change it....
Old Sep 16, 2007 | 01:10 PM
Crewrow's Avatar
Crewrow
Ya I think it's def. the one on top that connects the alt/power steering. I'm headed to the parts store to buy the gatorback. Thanks for your help.
Old Sep 16, 2007 | 04:39 PM
Butters00Vet's Avatar
Butters00Vet
What year is your Vette and how many miles you got on it?
Old Sep 17, 2007 | 07:11 PM
Crewrow's Avatar
Crewrow
It's a '99 with about 73,000 I think.
Old Sep 17, 2007 | 10:33 PM
Point & Shoot's Avatar
Point & Shoot
Old Sep 17, 2007 | 10:43 PM
JOEY P's Avatar
JOEY P
Maybe his belts have not been changed in 73000 miles thats why it broke.....Replace them both... The top one is easy but the bottom one is a little harder.....
Old Sep 18, 2007 | 06:58 PM
Crewrow's Avatar
Crewrow
Thanks for all your advice. I changed the top one last night and everything is running great. Noticed the bottom one was harder to get to. Will have to tackle that one a bit later
Now onto researching the site about headlight stuck up....sigh....
Old Sep 18, 2007 | 08:19 PM
LoneStarFRC
Just think of this as a "bonding experience" with your car.
Old Sep 18, 2007 | 09:52 PM
old stingray's Avatar
old stingray
To Belt busted...HELP
