Hard Clutch Pedal
Old Sep 2, 2007 | 11:25 AM
Z06KC's Avatar
Z06KC
Default Hard Clutch Pedal
Has anyone had a problem with the clutch pedal being hard to push in? I have a 2003 Z06 with 7700 miles.
Old Sep 2, 2007 | 12:53 PM
Brandon619's Avatar
Brandon619
I've had this problem before. It ended up being a broke slave cylinder. Is this a stock clutch?
Old Sep 2, 2007 | 01:48 PM
Z06KC's Avatar
Z06KC
Yes, the clutch is stock
Old Sep 2, 2007 | 07:23 PM
Ranger's Avatar
Ranger
What does the clutch fluid look like? Taking Care of Your Clutch
Ranger
Old Sep 3, 2007 | 11:45 AM
cruzin71's Avatar
cruzin71
I've heard of it happening. It could be a couple of things, slave cylinder or pressure plate,either way sounds like it needs to come apart for further assessment. I'd bet on the slave, cost of about $120.00 if you can do the install yourself. GOOD LUCK!
To Hard Clutch Pedal
