Where To Pick Up BPP Shifter?
Old Sep 2, 2007 | 07:56 PM
RrCoX22's Avatar
RrCoX22
Default Where To Pick Up BPP Shifter?
Where is a place that sells these? I've looked everywhere and can't find a spot where everyone is picking these up. I was originally looking for a Pro 5.0 but I guess those aren't made for the C5 and supposably the BPP throws even shorter than the Pro 5.0. I wan't the notchiest shifter.
Old Sep 2, 2007 | 09:03 PM
hotwheels57's Avatar
hotwheels57
Did you try BREATHLESS PERFORMANCE PRODUCTS (BPP)?
They're a site supporting vendor...go to the main menu and scroll down in the column of vendors to the left side.
Old Sep 3, 2007 | 01:26 AM
Dave68's Avatar
Dave68
I bought mine from LAPD. (slightly less expensive than BPP)
Install instructions are posted here:
http://www.conceptualpolymer.com/corvette_c5_corner.htm
Old Sep 3, 2007 | 01:44 PM
zeevette's Avatar
zeevette
Why in the world would you want the notchiest shifter? It just slows you down.
Old Sep 3, 2007 | 04:03 PM
hotwheels57
Aside from the fact that virtually every after market shifter available has its own peculiar "issues", BPP is what he evidently wants...
Old Sep 3, 2007 | 06:31 PM
Bill Dearborn's Avatar
Bill Dearborn
Just so you know. The BPP shifter is great on the 1-2 shift, the 2-3 shift and the 3-4 shift but absolutely crappy on the shift from nuetral into 1, the 3-2 shift or the 4-5 shift. I hated mine even with the lightest springs installed. Went back to the stock shifter which allows me to use my fingers to toss the shifter into gear without ham fisting it in my hand and jamming it.
Bill
Old Sep 3, 2007 | 06:41 PM
hotwheels57
...that will cut into some after market shifter manufacturer profits...
I'm still happy with my oem shifter as well, just took off 3/4" to make it a little shorter and changed out the ****.
Old Sep 3, 2007 | 07:18 PM
Dave68's Avatar
Dave68
After using my BPP for a couple of years, now, I still like it alot. The 2-3 shift is my favorite - faster than any other shifter I've tried. Of course, it certainly helps that I pump iron at the gym, three days per week, and maybe when I have bad arthritis, I'll go back to the stock or C6-style shifters. For now, the shifter is much faster than the rather long rowing I did with the stock shifter, but hey, to each his own. Everyone is different.
Old Sep 3, 2007 | 08:56 PM
RrCoX22's Avatar
RrCoX22
^that's good because i am basically looking for the shortest throw
Old Sep 3, 2007 | 10:20 PM
merven's Avatar
merven
If you have to pump iron just to shift the dam thing I want no part of it!!!
Old Sep 4, 2007 | 12:02 AM
Dave68's Avatar
Dave68
If you're not a limp-wristed woos, the shifting effort will be a piece of cake!
To Where To Pick Up BPP Shifter?
