Cam Pics-Opinions Wanted
Would this cam be reusable?
It makes a pretty paper weight though
But I would NOT install that. Unless you want to ruin lifters and have to the pull heads.
but he wanted to post up to see what the cause.I really don't wanna post this because it may stir up with Lou at LG.
I was one of the very first person to get on the first batch of G5X-2 cam. I got the cam installed at GM dealer during they did the re-rings.
Everything was stock except springs and push rods those came with the G5X-2 pkg.
The valve train noise level just keep getting louder and louder but I thought it is just because of the cam and springs.
To a point, I started investing to after market rockers since people said those would quiet down the noise. I got the Crank rockers on for a month and still got the same noise and started hearing those Crank rockers may fail so I took them off the put the stock lifters back on.
About 2 yearrs ago, I upgraded stock heads to 5.3 stage 2 with Patriot gold springs. When removing the stock heads, I found 3 or 4 stock lifters got eaten up. I then replaced those with new good ones but did not know the cam actually eaten up the lifters or vice versa ...
After I put in the new lifters, the valve train even more noisy than it was before. I thought because of the new valve springs which rated to 6.5 lift.
Recently, I added supercharger and swapped out the cam to notice those damages ...
So for those with big cam and noisy valve train, watch out
-Mike
They are not adjustable. However, when you add a high lift cam and don't change the push rods or get adjustable rocker arms you can put too much preload on the lifter by trying to have the rockers go back to the stock locations on the studs. IE too far down the stud. That will add preload.
