DIC Code in Plain English!?
Old Nov 8, 2001 | 10:10 PM
Greg00Coupe's Avatar
Greg00Coupe
Default DIC Code in Plain English!?
Got a DiC Code of 28TCS C 1241 H C which translates to "Magne Steer Circuit Malfunction Refer to variable effort steering on steering" Anyone know how to translate this into english and what it means????
Old Nov 8, 2001 | 11:33 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: DIC Code in Plain English!? (Greg00Coupe)
DTC C1241
Circuit Description
The Speed dependent Steering System (MAGNASTEER) incorporates its controller into the EBCM. The EBCM controls the amount of current supplied to the MAGNASTEER actuator based on input from the wheel speed sensors.
MAGNASTEER 2 also uses inputs from the wheel speed sensors along with added input from the Steering Wheel Position Sensor.
Conditions for Setting the DTC
One or both of the MAGNASTEER actuator circuit wires become open or shorted.
Action Taken When the DTC Sets
A malfunction DTC is stored. No ABS or Car Icon (TCS indicator) indicators are turned on but MAGNASTEER is disabled. ABS/TCS remains functional.
