MTI "Hammer Cam" questions........
Old Nov 7, 2001 | 11:53 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Default MTI "Hammer Cam" questions........
How is this cam for a daily driver? Too much?
Old Nov 7, 2001 | 11:59 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: MTI "Hammer Cam" questions........ (SurfnSun)
from what people have said, it is great, just ask RAT! :smash:
Old Nov 7, 2001 | 12:15 PM
97C5ENVY's Avatar
97C5ENVY
I'd recomend it even for a daily driver. If you don't mind a very mild "shake" at idle every so offen then i'd say get it. At cruising speeds you can't tell the difference from stock......except when you step on it. :D
Old Nov 7, 2001 | 01:21 PM
The One's Avatar
The One
Default Re: MTI "Hammer Cam" questions........ (2000^C5)
How does this Hammer cam compare to the T1?
JC
Old Nov 7, 2001 | 01:31 PM
G Man's Avatar
G Man
Default Re: MTI "Hammer Cam" questions........ (97C5ENVY)
Earnest
I'd like to meet up some time so I can hear the idle. I'm thinking about the hammer for my Hardtop. ;)
Old Nov 7, 2001 | 01:37 PM
tt427pacecar's Avatar
tt427pacecar
St. Jude Donor '05-'06-'07
Default Re: MTI "Hammer Cam" questions........ (G Man)
It would be a very good choice for you car. :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
Old Nov 7, 2001 | 01:38 PM
NineBall's Avatar
NineBall
Glad you guys are shopping. I'm about to post a group purchase on these MTI cams!
Hammer and T1 are VERY similar cams. Drivability will be the same. Only difference is 0.008" lift, so no change in drivability. Hammer will be a hair harder on the valvetrain, but thats it.
B1 cam passes emissions with catalytics. T1 sometimes passes.
Tony :seeya
Old Nov 7, 2001 | 01:45 PM
Ben01C5's Avatar
Ben01C5
Default Re: MTI "Hammer Cam" questions........ (NineBall)
Make sure you let us know when the GP is in progress.
Old Nov 7, 2001 | 01:46 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Nineball - if you had a cam with the same lsa (114) of the B1, same lift, but a higher duration (224/224) - would this pass as well as the B1? Just trying to understand these cams..........
Old Nov 7, 2001 | 02:32 PM
97C5ENVY's Avatar
97C5ENVY
Gary,
I'm off Monday (Nov 12th) and have already scheduled a dyno session with Colvin's at 10:00am. If you can stop on by.........if you can't make maybe we can hook up afterwards. LMK
Old Nov 7, 2001 | 02:50 PM
NineBall's Avatar
NineBall
Default Re: MTI "Hammer Cam" questions........ (OliverM5)
Oliver, each car is somewhat unique when it comes to passing emissions. Some testing centers might also have variances in their test equipment. Alot of variables to consider (cat brand, tuning, etc..)
As a general reply, you should seek lower intake durations and more lobe seperation in order to produce cleaner emissions test results. The B1 cam passes pretty easily with good catalytics on the car, the T1 passes on some cars but not other. Lift generally doesn't change much in terms of emissions testing results.
Tony
Old Nov 7, 2001 | 02:59 PM
DEAD EYE's Avatar
DEAD EYE
I'm going to explode if I have to wait to much longer for the next GP deal! :smash:
Old Nov 7, 2001 | 05:17 PM
G Man's Avatar
G Man
Gary,
I should be able to be there. I have an 8am conferance call, but it shouldn't go more than an hour. Look forward to seeing you there.
Old Nov 8, 2001 | 01:17 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Tony :seeya
Why is it harder on the valvetrain?? is it the extra bit of lift?
Old Nov 8, 2001 | 09:11 AM
rocketrider2's Avatar
rocketrider2
Will the C1 pass emissions? I think I am going to do this cam on this deal with MTI. I also would like opinions on doing the titanium retainers and also switching out the timing chain. Which chain would be recommended? Thanks.
Old Nov 8, 2001 | 11:41 PM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: MTI "Hammer Cam" questions........ (rocketrider2)
the cam is as tame at idle (900 RPM with custom PCM work) as the stock LS6 cam (although it shakes the car slightly :cool: ) ..... and drives like stock UNTIL.....UNTIL you mash the go pedal .... THEN HANG ON BUDDY !!!!!!!!
I LIKES IT :yesnod: .... hell the T1 is sweet too....and the B1 is killer as well.....but I chose teh hammer and am VERY happy with it :)
thanks
To MTI "Hammer Cam" questions........
