Underhood light????
Old Sep 5, 2007 | 10:54 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
Default Underhood light????
I can't get my underhood light to come on.
Checked the bulb, looks ok. What fuse controls this?
Inside / Outside fusebox? Which one?
Old Sep 5, 2007 | 11:10 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
check the connector plug on the passenger side of the shroud?
Old Sep 6, 2007 | 02:21 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Check the connection on the passenger side down low on the radiator shroud.
If you have a test light, pull off cover by squeezing the end and see if you have power.
Light could be bad as it has a gravity switch that activates it. Just got done fixing this in my Bro's FRC.
Also could have a dirty contact.
Old Sep 6, 2007 | 10:55 AM
JonLuvsVettes's Avatar
JonLuvsVettes
Old Sep 6, 2007 | 09:46 PM
johnnykretentiv's Avatar
johnnykretentiv
Mine doesn't work either. I just went out and checked and saw the light was unplugged. The previous owner must ahve unplugged it when he installed the intake. Where the hell does it plug in? I only have about 10 inches of slack so it can't be too far.
Old Sep 6, 2007 | 09:59 PM
SLPRC5's Avatar
SLPRC5
As mentioned..down along side the radiator on the pessenger side.
Old Sep 6, 2007 | 10:01 PM
SLPRC5's Avatar
SLPRC5
Does your vanity and enterance lights under the rear view mirror work?
If not it's the fuse in the box under the pass, footwell. I think it's #22.
Old Sep 6, 2007 | 10:09 PM
JLP's Avatar
JLP
Also check #2 fuse in the passenger foot well.
Old Sep 6, 2007 | 10:30 PM
johnnykretentiv
That is exactly where I am looking. Do have to take the damn radiator shroud off to get to this female end?
I guess I'll use a flashlight instead.
Old Sep 6, 2007 | 11:00 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's tough to find, it's all the way down on passenger side. Lift the hood and from the front bumper look down and you'll see it. A flashlight would be helpful.
Old Sep 7, 2007 | 02:36 AM
PUREFUN's Avatar
PUREFUN
Somehow mine got unplugged. I have a small hand and i couldn't see a way in there to replug it in So i'm all for the diy fix
Old Sep 7, 2007 | 09:49 AM
Zenak's Avatar
Zenak
I bet when i did my CAI 8 wks ago I unplugged it by accident pulling out that f-ing shroud to cut in for the Callaway. I'll check that this weeken. Thanks Tony :-)
Old Sep 7, 2007 | 10:20 AM
robdog289's Avatar
robdog289
I was cleaning under the hood one day and just saw mine hanging there. I plugged it in and low and behold my underhood light came on. Always thought the bulb was burnt out, go figure.
Old Sep 7, 2007 | 05:50 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Yeah Keith,
Taking out the fan shroud is not a lot of fun. Installing a varram is just as much a oain as the honker. Don't know if it's worth the 5HP.
Old Sep 8, 2007 | 11:17 AM
Zenak's Avatar
Zenak
It was just the plug! it took me all of 6 seconds to find it and plug it in!
Old Sep 9, 2007 | 12:05 AM
SLPRC5's Avatar
SLPRC5
Old Sep 9, 2007 | 12:07 AM
vetterlatethannever's Avatar
vetterlatethannever
Old Sep 9, 2007 | 12:38 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Well I guess we're all different. After 5 years of ownership and watching the light go on every time I opened a door or deck lid and never using the light under the hood I disconnected it while at a cruise in.
To Underhood light????
