So I drive the vette home from work last night (it is a 2001 A4) went in the house for maybe five minutes hopped back in and it wont start. There is a clicking/ticking sound coming from the chrome covered box next to the fuse box inside the car on the passenger side. When you put the key in and turn the acc on I get nothing no lights, radio, dome light nothing, when I turn the key as if starting the clicking stops but nothing else happens, it doesnt turn over or try to turn over like it would if the battery was dying. Where do I begin looking to figure this out??? What is the chrome covered box, and why would it be making a clicking sound? Greatly Appreciate any assistance!
Reach down beside the battery box and near the exhaust manifold and wiggle the big red wire going to the starter. It should have no movement on the starter post. If it does, you'll get the symptoms you have. You can disconnect one of your battery leads and tighten the nut on the starter post. If the bakelite that insulates the post from the starter has burned, the post itself will be loose and the starter must be replaced. If the post is loose, tighten the nut (slightly) to get the car started and get it somewhere to replace the starter. Also check your connections on the battery side of the cables for corrosion or loose fit.
Thanks 65GGvert, I have checked the battery connections and there is no corosion and they are not loose. So I will check the other stuff you mentioned when I get home this evening.
That box is the Body Control Module (BCM) which is one of several computers in your car. The BCM works together with the Powertrain Control Module (PCM), the computer that controls the engine and auto transmission, at engine start. The BCM controls relays that provide the IGN1 and IGN2 power to the Instrument Panel Fuse Block.
Unlike cars of "olden days" where, if you had a weak battery, you would hear the engine crank VERY slowly - or even just try to crank ... now when voltage is low the starter is never even asked to start the car. The computers know voltage is too low and to protect the starter they never even try it.
Sounds to me like bad battery or bad connections to the battery. How old is the battery ??
Try a jump and if it starts you probably have a bad battery.
