Need radio & security sys info
Old Sep 6, 2007 | 09:29 PM
hotmerc's Avatar
hotmerc
Default Need radio & security sys info
Had my Procharger installed & after getting the car back my radio is locked & remotes for security sys are inoperable. Are the 2 related & what can I do to repair? Thanks, Gerald T
Old Sep 6, 2007 | 09:43 PM
RPHCRMZ51's Avatar
RPHCRMZ51
You can do a relearn for the remotes via the DIC. As for the radio just look in your owners manual or do a search here and enter your secret code ( you did write them down ) If not, there is a thread here that tells you how to call GM and fix it. Hopefully others will chime in here and send some links. GOOD LUCK
Old Sep 6, 2007 | 09:49 PM
hotmerc's Avatar
hotmerc
Problem with the secret code is that I'm not the original owner.
Old Sep 7, 2007 | 12:04 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Look under OTHER and then in C5 TECH TIPS Its in there!
Old Sep 7, 2007 | 01:15 PM
hotmerc's Avatar
hotmerc
Thanks, I found it. Knew I had read it somwhere, just couldn't remember where.
Old Sep 7, 2007 | 02:03 PM
jirasvet's Avatar
jirasvet
FYI or any one
https://www.corvetteforum.com/techti...=164&TopicID=1
To Need radio & security sys info
