Easy Question?
Old Sep 7, 2007 | 04:56 PM
silverhead's Avatar
silverhead
Default Easy Question?
When I pull my DIC codes the one that concerns me is:
99 HVAC - NO COMM.
What does that mean?
Thanks,
George
Old Sep 10, 2007 | 02:23 PM
rcknusa's Avatar
rcknusa
I would like to know also.
Old Sep 10, 2007 | 02:45 PM
hotwheels57's Avatar
hotwheels57
http://forums.corvetteforum.com/show....php?t=1805449
Old Sep 10, 2007 | 03:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO COMMS means the serial buss for that module or the power for that module isnt working or has failed. Start with the fuses for that module and system. If the fuses are good, disconnect the MAIN connector to that module and make sure the connections are clean and the plug fits in the module tight.
You could also have a shorted serial buss wire in that module OR in another module. Do you get any other NO COMMS issues for other modules or any funky IPC or door control module problems???
If it is for the HVAC module, check to see if there are any other codes and if ther are clear them.
BC
Old Sep 10, 2007 | 10:16 PM
silverhead's Avatar
silverhead
BC
Bill:
Yes, I get other NO COMM on the following:
RTD - NO COMM
HVAC - NO COMM
SCM - NO COMM
Also, I can clear all codes and all start the car, immediately go back in to check codes and I get B0432HC.
As mentioned in another post, my A/C stopped working and the A/C screen is completely dark.
Thank you for your response.
George
Old Sep 11, 2007 | 09:20 AM
rcknusa's Avatar
rcknusa
You and I seem to be having the exact same issues right now. Seems like I get one thing fixed and another problems surfaces. Good luck to you.
Old Sep 11, 2007 | 07:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by silverhead
Bill:
RTD - NO COMM
HVAC - NO COMM
SCM - NO COMM
George
George
If you have NO COMMs it either means that the module/s is missing power or the serial buss for that module is open or shorted. Check power first.
Sounds like your missing power to the HVAC module. DTC B0432HC. is the rear window defroster relay which could be a fault of the HVAC No Comms issue.
Check fuses first.
BC
To Easy Question?
